Tire hum or???
Discussion in 'Wheels & Tires' started by alpinebob, Jan 20, 2013.
  1. Jan 20, 2013 at 6:37 PM
    alpinebob
    alpinebob [OP] Well-Known Member
    bob
    alpine ca
    2008 Tacoma 4x4
    I have an 08 Tacoma double cab 4 w d auto. I bought it last may with 86k miles.
    Runs FINE!
    Previous vehicle was a 95 Tacoma with 285 K miles and running great but I needed the full back seat room.
    About Three month ago I bought a set of Michelin Xts tires as the originals were getting a bit thin. The new tires ride and feel great, but I can hear and feel (in the steering wheel) a slight hum/vibration , mostly at 45-50 mph on any smooth road surface, wet or dry. As I said it is "slight" but I am keenly sensantive to vibs.
    My local Auto Tech has road tested it and thinks that it may be tire noise but he is not sure. Tire dealer says he has had no issues with these tires and has sold many sets over the past years. I had installed them on my 95 Taco and did not notice any "hum" and i know that the 2008 truck is quieter overall.
    Any thoughts?
    Thanks, Alpine bob
  2. Jan 20, 2013 at 6:38 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    wheel bearing starting to go?
  3. Jan 21, 2013 at 6:28 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Rotate the tires and see if the hum/vibe changes. Or even, change the tire pressure temporarily to see if anything changes. By doing this, could narrow it down to the tires.
    The new tires could actually hum......as part of the tire design. The vibration could be a balance issue - since you just got them installed..??
  4. Jan 21, 2013 at 10:42 AM
    REDTRD
    REDTRD Woods & Water Edition
    Anthony
    Western NC
    07 DCSB SR5 4x4
    Click my build thread!
    My cheap ass 245 Dunlop's just started doing this about month ago. I know these tires couldn't hum if they wanted to. But it honestly sounds like I have a set of 285 MT's on now. Usually does it anywhere from 30mph +
    Never thought about the wheel bearing Jamie, I guess that gives me somewhere to start.
  5. Jan 21, 2013 at 10:49 AM
    REDTRD
    Anthony
    Western NC
    07 DCSB SR5 4x4
  6. Jan 21, 2013 at 4:29 PM
    The_Hodge
    SC
    Mine started out soft and got louder.
  7. Jan 21, 2013 at 7:30 PM
    alpinebob
    bob
    alpine ca
    2008 Tacoma 4x4
    Thanks all for the replies.
    I have had tires rotated and balanced at Discount, they run very smoothly so I know the balance is good. I raised the tire pressure from 35 to 40 Psi, no difference in the sound.
    Today, I tried coasting in neutral , engine off, engine on, no difference at the "hum speed" of 45-50 Mph. had a buddy ride shotgun and he heard the hum too.
    I don't suspect a wheel bearing because the hum is very smooth not grating as a bearing will sound.
    In four thousand miles 90K I will have both front and rear differentials drained and refilled with synthetic lube, so I will not do it until then.
    As to the comment on the radio, I cant hear the hum with the radio on, or with a window open. It is really a low volume hum which seems to be totally speed related leading me toward tire vibration resonating somewhere in the body/chassis???
    alpinebob
