Tire inflation indicator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grsabourin, Nov 11, 2011.
  1. Nov 11, 2011 at 4:54 AM
    grsabourin
    grsabourin [OP] Member
    Hi,
    I recently change my summer tires for winter tires. For both set I have toyota mags. The summer set is the original truck mags and the winter set is an other set I have bought. With the summer set I'm able to reset the tire inflation sensor but with winter set it is not possible. Is it possible the sensors in my winter wheels are not recognize by the truck.
    Thank you
  2. Nov 11, 2011 at 4:58 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Yes, pretty sure the dealer has to calibrate them to your truck.
  3. Nov 11, 2011 at 5:03 AM
    grsabourin
    Only the dealer No way to calibrate by myself?
  4. Nov 11, 2011 at 5:09 AM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '10 Access SR5 4x4 4cyl
    You can by a tool off TireRack that allows you to reprogram for exactly your purpose. That is to maintain two sets of wheel/tires and swap the TPMS id's season to season. It is not cheap, but if you really want the dash light to go out for the season, the price of the tool is about twice the price most dealers will charge to reprogram them for you. So, in a year, after two switches, you've got your money back.
    The much cheaper option is to ignore the light half the year, and the only slightly more expensive option is to place a small piece of black electrical tape over the light on your dash for half the year.
  5. Nov 11, 2011 at 5:37 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Really, black electrical tape?
  6. Nov 11, 2011 at 6:24 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    X2
    LOL, I did this when I had my Dodge Ram with the ABS light! Traded it in like that too, not sure they even noticed!
  7. Nov 11, 2011 at 8:06 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Black tape is the way.... you don't even notice it. I do it in the FJ and the Tacoma, since I switch wheels between the two, along with a third set.
