Tire info needed about buying and tire facts
Discussion in 'Wheels & Tires' started by DangerTaco, Jan 24, 2013.
  1. Jan 24, 2013 at 7:56 PM
    DangerTaco
    DangerTaco [OP] The older the bear, the sweeter the juice
    Max
    Peninsula and the Delta
    '03 Tacoma TRD
    OME shocks/springs, Dakar leafs, Brembo Blanks, Hawk LTS pads, FJ steelies
    So i am currently in the market for new tires to go on my stock 17" alloys and while i was looking through the tire thread i saw way too many tires i wanted.
    Anyways, when it comes down to tire tread design, is there a way to be able to tell what situations theyd excel in?
    I know some tires are grooved to be able to repel water better, and some tires (slicks) are meant to have a larger contact patch so more grip.
    (Let me know if im making sense or not.)
    Some tires are better meant for city/highway driving than others that are better for offroad.
    And how do tire sizes affect road noise?
    Anyways, how do i go about determining which tires are best for me besides from looks alone?
  2. Jan 24, 2013 at 8:04 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    It's not really tire size that affects road noise, its the tread.
    As far as which tires, well that all depends on what kind of driving you will be doing. Is this truck your daily driver? Doing a lot of highway driving? Are you looking for a certain look for your truck?
  3. Jan 24, 2013 at 8:21 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    The farther apart the spacing between "lugs", generally the better off-road traction they will provide. This spacing will also (generally) increase road noise. The small zig-zag pattern molded into the surface of the lugs is called siping and helps to increase wet and icey traction. The modern five rib design helps to give great highway stability. Shoulder lugs of a random and varying size is supposed to help decrease highway noise. Alternating shoulder lugs of an M/T help to bite in the mushy stuff, but generally increase highway noise.
  4. Jan 24, 2013 at 8:24 PM
    DangerTaco
    Max
    '03 Tacoma TRD
    Yes its my DD.
    Its pretty much 50% highway, 40% city, and the other 10% for offroad.
  5. Jan 24, 2013 at 8:31 PM
    DangerTaco
    Max
    '03 Tacoma TRD
    Ah okay thank you for educating me.
    Well my tires havent given me any highway noise so far, might be due to the low tread.
    Does tread length also affect road noise?
    @deevon:
    Oh and as for looks, im not too picky, but some swamper tires would look sweet even though they wouldnt be what im looking for haha.
  6. Jan 25, 2013 at 12:54 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Well, I myself have an all terrain tire on my truck, but we also get snow here, so not sure if yours will need to be good in snow. But with that said, I would just Google, or you can check out discounttire.com, that's where I ordered mine from, and just see what you like.
    Also, an All Terrain aka A/T is going to be alittle more noisy, but will give you pretty good traction off road and on. I don't even notice the noise from mine anymore, not that they are that loud.
  7. Jan 25, 2013 at 8:14 AM
    Maticuno
    2011 Suburban 2500
    An aggressively styled all-terrain is probably what you are looking for. In that category, the Goodyear Wrangler Duratrac is highly favored among members here.
  8. Jan 25, 2013 at 7:23 PM
    DangerTaco
    Max
    '03 Tacoma TRD
    Oooh ill def check these out for next time.
    Just picked up some Maxxis Buckshot with FJ steel rims for 450 :D
    And since i live in Ca and get no snow in the part im in they should do good.
    Cant wait to do some mud slinging
