Tire Information needed please!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Swank, Jan 25, 2013.
  1. Jan 25, 2013 at 11:31 AM
    Swank
    Swank [OP] Certified Mall Crawling Instructor
    Steven
    Greenville NC
    SOLD/TOTALED
    Hey fellow TW members!
    I know this topic has been discussed multiple times, I just can't find what i'm looking for exactly so if you know, please inform me!
    I have a 08' TRD Offroad DCSB tacoma with 265/70R16 Yokahama Geolander A/T-S.
    Recently a friend and I put on a 3" spacer lift in the front just to give it a little bit of a lift (I don't do off-roading other than the occasional mud puddle, haha)
    but it has come time for some new tires and was wondering what size I could run without having to trim/mod little to anything to make them work without scrubbing and all.
    I was looking towards getting some 285/70/R16 BFG AT KOs or Goodyear Duratracs.
    (if you know something good and is cheaper, by all means, let me know!)
    Basically, I was wondering if the 285/70R16s would rub at all, and if so, what tire size would be good to put on it?
    Thanks for your time and looking! :eek:
    -Steven
  2. Jan 25, 2013 at 11:42 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If trimming, mud flap removal, gas milage and power loss is a concern you might want to just go with 265/75/16.
  3. Jan 25, 2013 at 11:50 AM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Well I wouldn't mind minor trimming, it's just the fact that i wouldn't know what I was doing. Mud flaps have been gone since i bought the truck, 2 days after actually, not worried about the MPG and power loss shouldn't be too bad.
  4. Jan 25, 2013 at 11:52 AM
    Larson7.62
    Larson7.62 Active Member
    Yuma, AZ
    Just helped my friend install a OME lift kit and 285/70/17 Tires with wheel spacers. He has to trim the flares and parts of the inner fender and looks like he has to do the cab mount chop
  5. Jan 25, 2013 at 11:53 AM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Ouch, sounds bad. Would I be able to run 275/70/16 by chance? If the 285s are too big?
  6. Jan 25, 2013 at 12:07 PM
    Ronin
    Ronin iTaco
    Al
    Rockwall, Texas
    2008 Tacoma Sport 4x4
    low range leveling kit
    I don't have a say in the tire size due to mine being a 17" wheel, but I do have a 3" spacer system w/ 285/70/17(s) tires. The one point of interest is that I had to purchase new uca(s) because my truck would "walk" on the road too much. Just FYI. Hope this helps. I like my space system. A lot of die-hards don't like them and I understand. It is fine for how I use my truck. Just wanted to let you know about the uca(s). If you stay w/the oem size tire...no worries.
  7. Jan 25, 2013 at 12:12 PM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Hmm, did you have to do any trimming to get them to fit or any modifications at all?
  8. Jan 25, 2013 at 12:19 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    I removed the mudflaps and did some plastic trimming with an xacto. was cake and I dont rub 99% of the time on road. that may vary with your driving style tho, but if you dont turn at full lock all the time or hit bumps at speed then youll be fine.
    youll prolly need either spacers or new rims for 285s tho btw. I dont regret them one bit tho. mpg loss is negligible with city driving and power loss wont be felt until you get above 55 really.
    Im running the bfg 285s w/ spacers. you can check my build thread for the specifics. :)
  9. Jan 25, 2013 at 12:21 PM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    You've given me hope. what type of plastic trimming are we speaking of? and 3" readylift spacer lift is what i have on mine.
  10. Jan 25, 2013 at 12:23 PM
    Ronin
    Ronin iTaco
    Al
    Rockwall, Texas
    I trimmed the mud flaps...just for aesthetics. I purchased the 3" spacer system, tires, and uca(s). I did a couple of the do-it-yourself mods. ie: diff breather, fog light mod. That is about it. Really happy w/the way my truck performs.
  11. Jan 25, 2013 at 12:38 PM
    TruKnight
    Tru
    Arkansas
    read build thread
    go have look in your front wheel wells, at the front, youll see a flimsy black plastic cowling thing that ends in a cup like thing. youll just get a sharp xacto and chop the lower bit of that off. cuts like butter. if you rub after that, youll see where it was it from the marks, and just chop that bit off too.
    you dont have to do a cab mount chop unless your going offroad. just refrain from turning at full lock on uneven surfaces and youll be fine.
  12. Jan 25, 2013 at 12:55 PM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Okay appreciate it guys. So I will be able to fit 285s with minor trimming? Thanks for all the help guys!
  13. Jan 25, 2013 at 1:02 PM
    TruKnight
    Tru
    Arkansas
    read build thread
    yep, dont forget to look at spacers or new rims also tho, youll need more backspacing with larger tires.
  14. Jan 25, 2013 at 2:15 PM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    What size back spacing do the black Baja rims have?
  15. Jan 25, 2013 at 3:06 PM
    TruKnight
    Tru
    Arkansas
    read build thread
    no idea. we do have an entire subforum on tires and rims tho. im sure someone else around here knows.
  16. Jan 25, 2013 at 3:15 PM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    So just to be safe, I should go ahead and buy 1.5" wheel spacers when I buy my new tires and I'll be set to go?
  17. Jan 25, 2013 at 4:07 PM
    TruKnight
    Tru
    Arkansas
    read build thread
    1.25" should work fine with stock rims. spidertrax is the favored brand around here I think.
    you should do some searching and read up on them tho before you buy. they are abit more maintence than new rims and some shops wont work on them.
  18. Jan 25, 2013 at 5:55 PM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    What do you mean by more maintenance?
    And new rims really aren't an option for me, too pricey. Haha so i'll have to stick to the wheel spacers :eek:
  19. Jan 26, 2013 at 3:24 AM
    TruKnight
    Tru
    Arkansas
    read build thread
    from time to time youll have to check the bolts to make sure there still tight. the same goes for the rest of your lift tho really.
  20. Jan 26, 2013 at 6:40 AM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Ahh okay. That's not too bad I guess. Now for the real choice.
    Which tires should I get? I want them to have an aggressive look, good in the mud if i decide to go through some, and a good wear life.
    Let me know if you know anything!
