Tire issues after Ball Joint replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by homer96, Apr 16, 2012.
  1. Apr 16, 2012 at 11:09 AM
    homer96
    homer96 [OP] Well-Known Member
    Josh...or Homer
    LaFayette, Georgia
    96 Tacoma 4x4
    Hella 500s, AFE pro dry, Pioneer head unit and Polk audio 650 speakers,
    My Goodyear Duratracs that were on the front of my truck until I rotated them this weekend are worn extremely unevenly. It is not just a small amount as it would be if I didn't rotate them like I should, it is in a spiral type pattern that is all over the tire not just on the outer or inner edges. The tires were so uneven that at low speeds, my exhaust rattled. The tire shop said it was my alignment that was causing this. I didn't have this problem until after my lower ball joint broke in October. I am thinking that I got a half ass alignment when I replaced all the ball joints, my right cv axle, and my tie rods in October. Is the tire wear caused by a bad alignment or is there something else? Thanks for any help!
  2. Apr 16, 2012 at 11:14 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    pics would help, but I would bet on the alignment
  3. Apr 16, 2012 at 11:14 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    exactly how are they worn?
  4. Apr 16, 2012 at 11:19 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Re-align and have tires balanced. This will eliminate a lot of things.
  5. Apr 16, 2012 at 11:22 AM
    homer96
    Josh...or Homer
    LaFayette, Georgia
    96 Tacoma 4x4
    They are choppy. It is kind of like every other knob is worn on both edges...It's really hard to describe.:confused: My dad is driving the truck this week. I'm 2 hours away from home at college so I cant take pictures. He is going to get an alignment sometime this week.
  6. Apr 16, 2012 at 11:22 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Sounds like cupping and a bad BJ would do that. Your tires where in essence rattling from side to side and you should of felt it in the steering wheel.
    I rotated my Duratracs once in over 30k and mine are fine...the fronts have rounded outer edges from driving thousands of miles aired down on the road (I'm a DB) but thats it.
  7. Apr 16, 2012 at 11:25 AM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    do they kindof feel like saw teeth when u slide ur hand over them? this is due to not roating enough. shity, because u cant really correct it once its been done. just drive it til they wear down and replace. Good year is notorious for using softer rubber. more prone to this happening. i rotate my duratracs every 3k
  8. Apr 16, 2012 at 11:25 AM
    homer96
    Josh...or Homer
    LaFayette, Georgia
    96 Tacoma 4x4
    I had them rotated and the ones that were on the back balanced, but the tire shop said that the ones that were on the front were too messed up to even try to balance. He said I should run them on the back and let them smooth out a little more before I balanced them.
  9. Apr 16, 2012 at 11:31 AM
    XXXX
    sKiP
    05 Prius
    Nope. My tires are 100% perfect except for the fact I drive on them while having 20psi in them.
    lol...3k rotation....I change my oil about every 10k and my tires get rotated at 10-20k. If I rotated as much as you I would do it 7 times a year and I'm way to lazy to do that.
    Soft rubber sticks to rocks and such better then hard. I love my Duratracs....just not for mudding and wheeling.
  10. Apr 16, 2012 at 11:31 AM
    homer96
    Josh...or Homer
    LaFayette, Georgia
    96 Tacoma 4x4
    Yes they feel like saw teeth when you rub over them. And the two that are chopped up have been on the truck since June of 2011.(I had one tire blow out and bought 2 instead of one) The other two have been on the truck since January 2010. The tire shop said that they were too choppy for it to have been from lack of rotation.
  11. Apr 16, 2012 at 11:32 AM
    homer96
    Josh...or Homer
    LaFayette, Georgia
    96 Tacoma 4x4
    I think I am just going to realign it and get new tires when I lift it. (which might be this summer)
  12. Apr 16, 2012 at 11:33 AM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    to each his own... but from experience thats what ive found
  13. Apr 16, 2012 at 11:36 AM
    homer96
    Josh...or Homer
    LaFayette, Georgia
    96 Tacoma 4x4
    You are probably right...I've drove around 12,000 miles without rotating them so that may be a lot of the problem. The older two tires don't have enough tread left on them for me to let them chop up like this so I guess thats why I'm worried.
