Tire/Lift/Wheel ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thereverend, Jul 24, 2014.
  1. Jul 24, 2014 at 8:03 PM
    thereverend
    thereverend [OP] rev
    Adam
    B'ham AL
    '14 DCSB TRD Sport 6spd SC
    TRD SC, URD 1 size smaller SC drive pulley, Volant CAI w scoop, TacoTunes full kit, MagnaFlow muffler for flow but ran out rear to kill the drone.
  2. Jul 24, 2014 at 8:06 PM
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    I'm pretty sure you should be fine without the UCA's. I may be wrong though...
  3. Jul 25, 2014 at 12:38 AM
    thereverend
    Adam
    B'ham AL
    The reason I am in doubt about the UCAs is I have a neighbor (queer as a 3 dollar bill so I know hw does no off roading) who had a 2010ish prerunner who has a set on stock toyota rims that he drive only on the street. These are nitto Terra Grapplers by th way. You can see on the UCA a ahint spot from rubbing and you can't even fit your hand between the tire and the UCA.
    MY concern is do I need the extra caster/camber/alignment issue type stuff new UCA will afford me? Will leavin stock UCAs cause wear issues? Will the new UCAs make new BFGs last longer. Mine too is a mall crawler if that matters.
    Thanks for sharing your knowledge,
    Adam
  4. Jul 25, 2014 at 12:51 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    you only need new UCA's if your going over 3". Your neighbor was probably running too big of a tire or had other issues. But you should only need new UCA's if you are going to a three inch lift. You are going to be at 2.5 so you can run stock UCA's.
  5. Jul 25, 2014 at 4:18 AM
    thereverend
    Adam
    B'ham AL
    Thank you Taco Freaks!
  6. Jul 25, 2014 at 4:52 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    What size tires is your neighbor running?
    With 285s, you will also probably rub the UCA if you're on stock wheels. It's all in the backspacing. If you don't want to get wheels, you can run spacers for now.
  7. Jul 25, 2014 at 5:07 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    This would be the cheapest route
