Tire light on, won't go off
Discussion in 'Wheels & Tires' started by dinki, Dec 1, 2014.
  1. Dec 1, 2014 at 12:36 PM
    dinki
    dinki [OP] Member
    13 PreRunner I4
    Hey guys. I've got an I4 Tacoma '13 with stock/factory tires. Winter has come and my tire pressure light came on. I checked all my tires and all were at 30 psi. I tried checking the spare but the valve was facing the bed so I lowered the tire and flipped it over for easier access and cranked it back in place. I checked that tire and it is also at 30 psi.
    I checked the tag in the drivers door and what I understood it to say is that all tires should be at 30 psi. Can anyone tell me why the light might be on if the tire pressure is correct?
  2. Dec 1, 2014 at 12:37 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Mine does the same. Had it reset at the dealer and it was off for about 3 weeks, back on again ever since except for half a day.
  3. Dec 1, 2014 at 12:38 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    When you turn the truck on and start it, does it blink for 2 minutes? That indicates a bad sensor.
    12+ don't have TPMS on the spare IIRC, my 2013 does not.
  4. Dec 1, 2014 at 12:38 PM
    LBCdan
    LBCdan TACO --> TUNDRA
    Dan
    Long Beach , CA
    2018 Tundra CM 4x4
    Toytec Coilovers, TotalChaos UCA, Icon w/ Resi, Toytec Lift Shackle, Methods w/ 285/75/18 Tires.
    does the spare tire have TPMS in it?
  5. Dec 1, 2014 at 12:40 PM
    geekhouse23
    Spares***
    Sorry!
  6. Dec 1, 2014 at 12:41 PM
    T4RFTMFW
    Someone said a few weeks ago that the last year the spares had TPMS was in 2011. I haven't checked mine, but FWIW all the pressures are GTG on my particular truck. I had the dealer flip the spare over and remount with the stem facing down just for this reason.
  7. Dec 1, 2014 at 12:46 PM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    My spare had a tpms sensor my light won't go out had it checked front driver side is bad any Way to take a fuse our or something.
  8. Dec 1, 2014 at 12:49 PM
    dinki
    dinki [OP] Member
    13 PreRunner I4
    Thanks. All tires have the same pressure and it matches the door sticker so I'm guessing that it is correct.
  9. Dec 1, 2014 at 1:23 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    There's a reset switch for it (on mine anyway) below the steering wheel. It tells you how to reset it in the owners manual.
  10. Dec 1, 2014 at 1:25 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    46psi!!!!! Are you sure you're not driving a fullsize?
  11. Dec 1, 2014 at 1:47 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    The reset switch is dead center under the steering wheel on the bottom edge of the lower dash panel. Set your air pressure as desired and then press and hold the button for a few seconds.
    I run 36 psi up front and 42 psi in the rear on Cooper 265/70 17 AT3's. No TPMS warning light issues whatsoever.
    I would, however, like to know how to de-activate the darn thing, as I'm gonna put some big-ass wheels and tires on the truck and don't want to have to break them down to install the sensors.
  12. Dec 10, 2014 at 11:56 AM
    CanadaToy
    Greg
    Toronto
  13. Dec 14, 2014 at 6:58 PM
    taczilla
    Marc
    2016 RAM Rebel
    I just put a set of Mickey Thompson 17x9 wheels and 33" ATX P3's without sensors.
    NO TPMS LIGHT!
    :yes:
