Tire light when on after installing my MT wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jose, Nov 14, 2011.
  1. Nov 14, 2011 at 1:59 PM
    Jose
    Jose [OP] Well-Known Member
    Jose
    SoCal
    2012 trd tacoma
    Hey guys my tires psi light when on today after like 3 days of driving it with my after market wheels.. Would I have to buy sensors for my after market wheels??? Or whats the proses?? thanks
  2. Nov 14, 2011 at 2:05 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Well if you don't have sensors in your wheels the light is going to come on. Or if you're running higher or lower PSI then what the sensors are set for it will come on.
  3. Nov 14, 2011 at 2:07 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    First, check the tire pressure in all 5 tires. If they are all at where you want them and equal, read your owners manual for re-setting tire pressure monitor.
  4. Nov 14, 2011 at 2:08 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    and if not one of them is broken
  5. Nov 14, 2011 at 2:34 PM
    A fire inside
    A fire inside Member
    If your light is solid then you have low pressure. If it blinks for 1 minute then goes solid, you have a MIL or Malfunction indication lamp. If it blinks you have a sensor issue. Check you pressure a lot more often when the ambient temperature outside drops. Battery life is usually 5 years or 100k miles, by the way.
  6. Nov 14, 2011 at 4:46 PM
    Jose
    Jose
    SoCal
    2012 trd tacoma
    Thanks guys.. My mickeythompson wheels dont have any sensors in them, as fas as i know since i bought them used. Do are OEM wheels have sensors in them?? Im thinking its the PSI I havent checked them since i put them on..
    Its a 2012 so i dought the sensors are bad, but you never know
  7. Nov 14, 2011 at 5:38 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The sensors are mounted on your stock rims, which are no longer on the truck.
  8. Nov 14, 2011 at 5:42 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Mine took a few days to come on. Just put the sensors in a pressurized vessel, like pvc pipe and throw it under your seat or you will get use to the light.
  9. Nov 14, 2011 at 5:44 PM
    TexasTacoma37
    The shop could have swapped the sensors to the new wheels rather easily
  10. Nov 14, 2011 at 5:48 PM
    Fiolo
    Fiolo Senior member
    1998 Tacoma, 2022 Tacoma, 2019 L5P Duramax
    Lost track many mods ago
    Yep
  11. Nov 14, 2011 at 8:51 PM
    Jose
    Jose
    SoCal
    2012 trd tacoma
    I bouth the wheels used with tires.
    I was thinking of buying new sensors for my wheels. manley because my truck still has warrenty for the nxt 6years..
    Were can get them and how much are they??
  12. Nov 14, 2011 at 9:05 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I'm not sure about the Tacoma ones, you can get them at any tire shop but they might have to order them in if they don't have enough in stock. I work at a Discount Tire, and they run anywhere from $50 to $150 a piece
  13. Nov 14, 2011 at 9:36 PM
    Jose
    Jose
    SoCal
    2012 trd tacoma
    Thanks brotha. :cheers:
    And your point?? :notsure:
  14. Nov 14, 2011 at 9:44 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Why don't you just use the ones that came on the Tacoma? I just got wheels put in and rather than spend the extra money on the sensors and the seal kit, I just had them put the original ones in. Should save you a good amount of change! :)
  15. Nov 14, 2011 at 11:25 PM
    Jose
    Jose
    SoCal
    2012 trd tacoma
    Manley because of my truck is still under warranty. I dont want them later on, down the road to blame on the aftermarket wheels if a suspension part gives out.. the dealers are PITA when it comes to warranty a part.. Yall get me.
  16. Nov 14, 2011 at 11:29 PM
    babytruck
    NorCal
    I don't understand how putting the TPMS in the new wheels would place blame should the suspension have any issues. TPMS has nothing to do with suspension. There are sensors in the valves that communicate with the reader in the truck, that's all. From what I understood, they have to prove that any modification has caused another part to fail. What they don't cover is what you took off and replaced. In other words, the new wheels will not be under warranty, but everything else around it should be.
    Maybe the seals around the TPMS won't be covered because they may become damaged during removal.
  17. Nov 14, 2011 at 11:32 PM
    creeper
    creeper Well-Known Member
    Ummm his point is that you took the wheels WITH the tire pressure sensors in them off the truck...and now you don't understand why your TIRE PRESSURE LIGHT is on...
  18. Nov 15, 2011 at 4:19 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Got to agree .... kinda like ... :rasta: ... let me see .....
    "I used to use a prophylactic that my old girlfriend would drop onto my night stand. I traded her in but, the "new" girlfriend didn't come with any and I don't understand why she is pregnant."
    Yep ... that pretty much sums it up. :D
  19. Nov 15, 2011 at 8:59 AM
    JRader1790
    JRader1790 Well-Known Member
    Josh
    Pascagoula
    '11 TRD Sport 4x4
    May be a dumb question, but I'm not positive on the answer. Is it possible to just mount all of your tpms sensors in the spare tire and keep it aired up? Just a thought for those that don't want to deal with it..
  20. Nov 15, 2011 at 9:04 AM
    TexasTacoma37
    It is possible, but you can't really "mount" them. You would just have to throw them in there, and they would tumble around if you ever used the spare.
