Tire limitations for SR stock steelies?
Discussion in 'Wheels & Tires' started by Oakmulgee, Sep 3, 2022.
  1. Sep 3, 2022 at 7:23 PM
    Oakmulgee
    Oakmulgee [OP] Member
    2017 Tacoma SR 4x4 (double cab)
    - Old Man Emu lift (front configuration: 2" lift (2887) with softer valving (90021); rear configuration: 2.5" standard Dakar Leaf Pack (EL111R)). - Old Man Emu upper control arms - Yota Mafia extended brake lines - East Coast Gear Supply clamshell bushing - U-Bolt flip kit - DuroBump bump stops (front and rear) - Front Runner SlimLine II low profile roof rack - KC FLEX ERA 3 Dual Mode SAE Fog Lights - TRD Pro skid plate - Tacoma Trail Edition bronze wheels and grill - Alu-Cab Contour Canopy - BedRug Bed Liner + plywood sleeping platform - Clazzio leather seat covers - 4.88 Nitro Gears - Rear E-locker - Cooper S/T Maxx 255/85/16
    Small lift coming for my 2017 SR, and I don't have a reason (or none that I'm aware of) to get rid of my stock steelies. I do want slightly larger tires, and I've been aiming for something in the 265/75/16 size. The closest thing would be 285/75/16 for some tires (e.g., Cooper AT3).
    Before I go too far down this rabbithole, have people encountered any tire size limitations (e.g., backspacing, offset, etc.) with the stock steelies?
    (FYI, I'm going with the OME 2" lift kit: 887 light load front coil; 90021 soft valving; and 2.5" rear 111R standard / medium load Dakar Leaf Pack; not sure about UCAs. I want to maintain a decent ride on the road, but have capable tires for backcountry truck camping a couple times per month.)
  2. Sep 3, 2022 at 7:40 PM
    Bishop84
    Bishop84 Well-Known Member
    So width comes into play before backspacing.
    The steel rims have 7" width, and 285's suggest 7.5 minimum. Meaning the tire would have a bulbous effect and mostly center wear.
    Ideally with a 4 banger its best to stick with maxing out with the 265/75R16 size. This size has the most selection.
    The bigger 255 85 16 size will rob gearing but will sit best on the rim and perform better offroad.
  3. Sep 3, 2022 at 7:50 PM
    Oakmulgee
    Thanks - that is super helpful and settles the issue for me (almost). It's a SR 4x4 with V6, but it seems like the 265/75/16 will be a good choice (though I will look into the 255/85/16).
  4. Sep 4, 2022 at 8:23 AM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    255/75/16 would be my choice.
