tire load range
Discussion in 'Wheels & Tires' started by vtragweed, Oct 27, 2008.
  1. Oct 27, 2008 at 3:30 PM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    im looking at getting a set of tires. the factory tires that came on the truck are standard load 4-ply the set of tires im looking at come in 4-ply 13/32 tread and a 6-ply with 16/32 tread i dont mind giving up a little stiffer ride but tell me what yall think
  2. Oct 27, 2008 at 3:32 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    my ride didnt change to much just didnt run them at 65psi kept them at 55psi thats what the tire shop told me to do
  3. Oct 27, 2008 at 3:42 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    they are both the same size just different load ratings, my stock tires only call for 29 psi so if i went with the c range what psi should i run them at
  4. Oct 27, 2008 at 3:55 PM
    2003greenbean
    socaste,sc
    03 trd
    if the ride is stiff drop the psi 5 see if its any better your tires will wear alittle quicker
  5. Oct 27, 2008 at 4:34 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    so would you run the 6-ply tires at the same psi as the 4-ply
  6. Oct 27, 2008 at 5:09 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    one of the guys told me that you should put the max psi in the tire thats allowed
  7. Oct 27, 2008 at 5:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can do that, but the tires will probably wear funny a bit, and mileage may go up some........but the ride will be bouncy and harsh,im pretty sure anyways.
  8. Oct 27, 2008 at 5:14 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    so my stock tire is a 4-ply and if i move up to a 6-ply just keep stock psi(29) in the 6-ply
  9. Oct 27, 2008 at 5:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well.....not exactly. adjust the air pressure to what is comfortable to you. you could probably run 35 to 36 in the front, and 32 to 33 in the rear...see how that does for ya.
  10. Oct 28, 2008 at 2:39 PM
    2003greenbean
    socaste,sc
    03 trd
    i was running 8 ply and couldnt drivr it at full psi it was to bouncy
  11. Oct 28, 2008 at 8:02 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...Adjust your tires to be confortable and wear evenly. but on the flip side of that...Make sure once you are comfortable with the ride and the wear pattern...that the PSI is within the manufacs allowable range.
