Tire look flat?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hauser94, Dec 28, 2023.
  1. Dec 28, 2023 at 10:30 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    That calculator is for calculating PSI to maintain your factory load capacity....like it says right on the results. Doesn't mean that's the proper amount to inflate the tire to for ride quality/braking/handling/tire wear.
    It looks under inflated BECAUSE IT IS. Gonna have yourself some sweet body roll taking a corner with any amount of speed.
  2. Dec 28, 2023 at 10:48 AM
    Hauser94
    Hauser94 [OP] Well-Known Member
    2016 Black Tacoma SR5 DCSB
    So you think I’d be best suited to go back up to 32?
  3. Dec 28, 2023 at 10:53 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Happy early Friday
    Stevie17 and TexasTacoLT like this.
  4. Dec 28, 2023 at 11:00 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Just purchased new tires. 245-75-r16. Goodyear workhorse ht. They set them to 36. They run fine ..good luck
  5. Dec 28, 2023 at 11:04 AM
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    Stevie17 likes this.
  6. Dec 28, 2023 at 11:21 AM
    Hauser94
    Alright relax lmao just the 3rd person to say something so I second guessed a little just wanted to come to my peers to see if anyone knew a little more than me
  7. Dec 28, 2023 at 11:27 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Chalk test and call it a day
    Hauser94[OP] likes this.
  8. Dec 28, 2023 at 11:34 AM
    Hauser94
    Understood I’m gona try that
    TexasTacoLT likes this.
  9. Dec 28, 2023 at 11:38 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There is the number on the door jamb, that's pretty much minimum. And there is a number on the tire, which is maximum for that tire, and probably more than the truck is rated for. Somewhere between those is where you want to be.
    musicisevil likes this.
  10. Dec 28, 2023 at 11:43 AM
    TacomaAddict23
    TacomaAddict23 There's no cure for dumb
    2023 Lunar Rock DCSB
    Ditch Lights 4wp Sliders Bed side molle panels Taco garage DMM mount More to come
    Meh looks fine. Just spin em till they pop! :burnrubber:
  11. Dec 28, 2023 at 12:37 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I think 30 cold is perfect. I ran that on my stock tires, my 285/70/17s are aired up to 30 as well. Rides perfect, wear is perfect and doesn't look flat. Try 30 and see how it does.
