Tire low warning is wrong
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jlcjr, Feb 24, 2011.
  1. Feb 24, 2011 at 8:57 AM
    jlcjr
    jlcjr [OP] Member
    Lincolnton County GA
    07 basic, 03 Jetta TDI
    Yep, Added air to those that needed it even the spare (which I flipped over) and the warning is still lit. Is there a fix. Have y'all approached this before?
    I ignored this for months and needed to drag a U-Haul home from Savannah figured I'd better check the spare...if was full.:rolleyes:
  2. Feb 24, 2011 at 9:01 AM
    Xshark
    Xshark Well-Known Member
    Michael
    Rogers, AR
    08 Taco
    Icon progressive leaf, 3-leaf pack. Bilstein 5100's on all corners, front set at 2.5" Spidertrax wheel spacers Satoshi Grille Mod
    Did you press the 'reset' button under the dash by your knees? (Its in the manual)
  3. Feb 24, 2011 at 9:11 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    ^This... The manual he is referring to is the Owner's Manual. It's a couple hundred page book that comes with the vehicle and is traditionally kept in the glove compartment :D
  4. Feb 24, 2011 at 9:14 AM
    jlcjr
    jlcjr [OP] Member
    Thanks I was hoping I didn't need to troubleshoot.
  5. Feb 24, 2011 at 9:18 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Not really a troubleshoot item .... a few simple steps ....... give it a try.
  6. Feb 24, 2011 at 9:19 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Did the 07's come with the 'set' feature ? I may be wrong but I thought that was a later addition .
  7. Feb 24, 2011 at 12:03 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    it is amazing how few people READ the owner's manual.
    i read it cover to cover. i dont memorize shit, but if something does need addressing, i will remember vaguely, if the info is even in there.
    crack the book.
  8. Feb 24, 2011 at 12:11 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    My 07 has the tpms reset feature.
  9. Feb 24, 2011 at 12:12 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    My 07 has it. I pushed it once when my light came on. It didn't fix it. Adding air to the spare did though.
  10. Feb 24, 2011 at 1:47 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    went and test drove my truck from the guy i bought it from (a few months ago), the next day he told me the light had turned on but the tires seemed fine. . . the day after that i drove it to my import mechanic for a complete lookover before i bought it, he checked the spare, all 4 and reset the button and he knows toyotas like the back of his hand, nothing. i check em all every week and hit the reset the way the manual explains but the light doesnt turn off. ive just learned to live with it.
  11. Feb 24, 2011 at 2:05 PM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    One of the sensors is probably bad. You'll probably have to get them tested to find out which one.
  12. Feb 24, 2011 at 2:24 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    my 07 doesnt have the reset button
  13. Feb 24, 2011 at 2:27 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Never used a reset switch on mine. It just took a little bit to clear on its own. same thing on the wifes car a couple weeks ago.. added air to the spare... she says the light is still on.. i said wait a day. sure enough.. it went off and hasn't come back.
  14. Feb 24, 2011 at 2:37 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    I actually have to check my spare because my TPMS light has been on for almost a year now haha. Just been lazy because I don't know where I put the key for the spare lock.
    In fact, I'll go look at it today :D
  15. Feb 24, 2011 at 2:49 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    With all five tires at the pressure on the door jam, press the reset button. When it blinks three times, it is reset. If the light blinks without you pushing the button, there is a problem with one of the sensors. If the light is on steady, one of the tires is lower than what is set from the last reset.
    If you are asking this question on this forum, you have not made use of the wonderful search function this site offers;) This topic has already been covered.... blah, blah, blah....
  16. Feb 24, 2011 at 7:22 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    The tires can have whatever pressure you want in them.When you reset the light,it is reset to that pressure.
  17. Feb 27, 2011 at 4:06 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    EDIT: Mine does have it, I guess I never noticed it before.
    I finally lowered the spare, found that it had only 10 psi left in there. Aired it up, used the reset button and voila! the damn TPMS light finally went away :)
    Funny how I was too lazy to do this for about a year and had that TPMS light blaring at me for that long. :(
  18. Feb 28, 2011 at 7:09 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    My 2010 spare doesn't have a sensor
  19. Feb 28, 2011 at 7:22 AM
    MQQSE
    MQQSE Random Member
    Rob
    Palmer, AK
    Call mine the "Good Traction Light"...worthless system.
    IMHO it's a dealer ploy to have people pay them to reprogram the system when the reset button doesn't work.
    I just go "OLD SCHOOL"...keep an eye on my tires and check the pressure 2-4 times a month. Made it nearly 46 years, 30 years driving, and never needed an idiot light for tire pressure.
  20. Feb 28, 2011 at 8:29 AM
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    x2 I heard they were an add-on after the Expedition roll overs, but still find them absolutely useless
