Tire measurement - is this guy correct?
Discussion in 'Wheels & Tires' started by Iakopa84, Aug 8, 2011.
  1. Aug 8, 2011 at 3:29 PM
    Iakopa84
    Iakopa84 [OP] Well-Known Member
    Jake
    Escondido, CA
    05 PreRunner TRD Off-Road
    Aries Grille Guard, PIAA 520 xtreme ATP lights, K&N high-flow intake, 2.5" velocity front leveling kit
    I went to ORW to get a tire quote about putting some BFG's on my stock rims and what the biggest size I could go without them rubbing.
    I have a 2.5" leveling spacer on the front (am going to replace with a T.U.L. kit)
    He said I could run (on the stock rims) 285/75/16 without them rubbing and that the rim width isn't too small for that size.
    That size sounds a little large to me... is he correct in saying that I could run that size on that rim without any issues?
  2. Aug 8, 2011 at 3:32 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You should be able to run those with some wheel spacers and some minor trimming up front.
  3. Aug 8, 2011 at 3:44 PM
    Iakopa84
    Jake
    Escondido, CA
    Hmmm... I'm trying to avoid the trimming
  4. Aug 8, 2011 at 3:45 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Honestly its not a lot of trimming. Plus the plastic you trim is thin and flimsy so its easy to cut. I just used a little dremel and that worked like a champ!! You wont have to cut anything that will mess with the trucks frame.
  5. Aug 8, 2011 at 3:46 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    If you dont want to trim get the 265/75/16. I run these on my truck with a 3 inch lift.
  6. Aug 8, 2011 at 3:48 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Or you can do this OP and go the other route. It all just depends on what look you want and how hard you plan to off-road. I wanted the more aggressive look so I went with the 285's. I still rub a tiny bit at full lock in reverse sometimes.
  7. Aug 8, 2011 at 4:00 PM
    Iakopa84
    Jake
    Escondido, CA
    Thanks for the advice!
  8. Aug 8, 2011 at 4:05 PM
    jandrews
    '09 FourDubDee TRD OR
    If you flex the truck you will rub like a motherfucker.
    Trimming will get you by over the road, but if you actually wheel it you'll need cab mount chop, trimming, pinch weld beating, and ideally some new wheels.
    If you're a streeter you'll be fine.
    Edit: Saw you're a prerunner. You'll be fine.
  9. Aug 8, 2011 at 4:07 PM
    Iakopa84
    Jake
    Escondido, CA
    I am planning on some off-roading (back country trails and roads, etc)
    May do some 275's to be safer
