Tire noise or wheel bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2008TRD4me, Mar 16, 2020.
  1. Mar 18, 2020 at 9:00 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    A good way to check for a dry grindey bearing is to jack up the front and spin the tire by hand with a hand on the strut. Compare both sides and you can literally feel the grind and roughness of the bearings. For rear just put the rear end on jack stands and put it in drive and listen with a screwdriver on the end of the axle. A decent ear should be able to tell the difference
    dk_crew likes this.
  2. Mar 18, 2020 at 12:20 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Replace the wheel bearing. The reason it goes away is because you’re unloading that bearing as you turn.
    Skyway likes this.
  3. Mar 18, 2020 at 3:17 PM
    2008TRD4me
    2008TRD4me [OP] Member
    2008 TRD Sport
    Toytec 3"lift 285/70/17 tires
    Thanks everyone!! The driver front bearing was shot, but the wheel had no wiggle play. I changed both bearings, truck is quiet now!! Success!!
    Delta09, dk_crew, JerzRob and 3 others like this.
  4. Mar 18, 2020 at 3:55 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Awesomeness!
    Stick around a while.... :cheers:
    2008TRD4me[OP] likes this.
