Tire Offset Decision Help!
Discussion in 'Wheels & Tires' started by SilverSprt, May 28, 2013.
  1. May 28, 2013 at 6:46 PM
    SilverSprt
    SilverSprt [OP] Member
    Virginia Beach
    265/70 R17 Toyo Open Country AT 2, 17x8.5 V-Tec Warlords, Bilstein 5100's
    Looking at some 17 x 8.5" rims ( 6-139.7) for my 2013 DC. They come in a few different offsets / backspacing and not sure what one I should get. I want a little wider stance than stock but not rock throwing wide . It is not lifted now but am looking into leveling it out soon. Would like to run 265/70 R17's right away. I know the stock 17" TRD's are 17 X 7.5" w/ 5.5 BS and 30mm offset. Dont want to run spacers either. Listed below are my rims size options:
    4.25 B/S -12 offset 106.2 center bore
    5.25 B/S +12 offset " "
    5.7 B/S +25 offset " "
    6.1 B/S +35 offset " "
    Thanks in advance.
  2. May 28, 2013 at 7:01 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Either of the above choice will work. 4.25" BS will give you flexibility if you decide to go wider than 265s in the future. The drawback is that you'll have to do some minor plastic trimming.
    5.25" BS will work out with the current tire size selection and you probably will not have to do any trimming, but if you decide to go with wider tires, you will run into some rubbing on the UCA.
  3. May 28, 2013 at 7:04 PM
    SilverSprt
    Virginia Beach
    Out of those two choices, how far would each of those stick out approximately? ??
  4. May 28, 2013 at 7:07 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    4.25" BS will stick out about 2.25" more than stock.
    5.25" BS will stick out about 1.25" more than stock.
