Tire options for 18 inch wheels on a 5 lug?
Discussion in '5 Lug' started by JakeBrakes, Jan 2, 2024.
  1. Jan 2, 2024 at 4:01 PM
    JakeBrakes
    JakeBrakes [OP] Member
    Jake
    2010 Regular Cab Tacoma 5 lug
    Volant CAI 15"cast aluminum wheels 235/75/15 Wranglers
    Hey guys I’m thinking of buying these wheels/tires from a co-worker of mine. I want to replace the tires. what size should I get for an 18 inch wheel? These are 225/45/18
  2. Jan 2, 2024 at 4:13 PM
    Clearwater Bill
    Billy
    Largo Florida
    X runners are 5 lugs and came with 18" if you want to research that.
    But I'd wager those pictured wheels won't have the same specs as OE wheels. Which could definitely impact tire size and clearances
    Proceed with caution.
  3. Jan 3, 2024 at 10:44 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    Equivalent size tires for 18s would be 225/50 if you want to keep the same width as what is on the wheel currently. Looking at them it looks like the tires are slightly stretched so they would probably be better suited to have 245/45 tires on them. As mentioned above you need to check clearances due to what are probably different width and offsets from stock for the truck.
