Tire or Wheel balance issue - trouble shooting
Discussion in 'Wheels & Tires' started by auskip07, Jul 14, 2022.
  1. Jul 17, 2022 at 2:38 PM
    auskip07
    auskip07 [OP] Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Yes the wheels appear to be similar. I'll start looking for a shop that can balance with the lugs. Otherwise I'll ditch the rims and put my steelies back on for the time being
  2. Jul 19, 2022 at 8:09 AM
    auskip07
    Skip
    Atlanta, Ga
    Called a few shops and no luck on lug balancers. they advised me to get the hub rings. i just bought a new set of rims and will go that route.
    splitbolt likes this.
  3. Jul 19, 2022 at 1:44 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Good call...
    You don't really know which is off from center of the entire wheel.
    If it's the bolt circle, lugcentric balanced wouldn't have helped.
    That was a lot of difference between the bolt circle and hub bore. I wasn't expecting it to be so apparent.
    auskip07[QUOTED][OP] likes this.
  4. Aug 14, 2022 at 10:32 AM
    auskip07
    Skip
    Atlanta, Ga
    Changed out the rims, yesterday for a set of hub centric. It does ride a lot better overall but as some mention above the braking issue is still present. So I'll replace the rotors while doing a brake job). Wanting to get this figured out before I install the lift and try to troubleshoot any new issues that will cause. Appreciate the help
