Tire Piece Missing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by randy08, Aug 11, 2025 at 12:06 PM.
  1. Aug 11, 2025 at 2:24 PM
    randy08
    randy08 [OP] Member
    I tried the penny test and it’s not quite to Lincoln’s head yet
  2. Aug 11, 2025 at 2:27 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    Tire made 45th week of 2022
  3. Aug 11, 2025 at 2:28 PM
    randy08
    randy08 [OP] Member
    Yea but then that doesn’t tell me when they were put on cause they could’ve sat at a shop.
  4. Aug 11, 2025 at 2:34 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    That doesn't matter. Date of manufacture is your concern. Tires stare off-gassing from the moment they are removed from the mold.
    As for the sidewall...it doesn't look from your picture that the carcass is damaged. I'd run them without a qualm.
    lowmower and 2015WhiteOR like this.
  5. Aug 11, 2025 at 3:02 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    post a picture of the actual face of the tire, the tread....
    wheel turned so we can see all of the tread..
  6. Aug 11, 2025 at 3:14 PM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Don't worry about the penny, the tire has built in wear indicators you can use.
    These are raised bars between the treads, running crossways across the tire. Once the tire tread wears down to even with those bars, you are due for a replacement (some would say beyond due).
    45th week of 2022 is less than 3 years ago, I think people are being dramatic on the age.
    I drove a long time on a tire with a nice gash in the sidewall, probably wouldn't do it these days. I'd poke my finger in there and think about how deep it is. Tire sidewalls are a lot thinner than you'd think.
    I'd most likely replace it. And if tread depth is more than half of that of a new tire, I'd probably replace just the one, but depending on wear, you may want to replace two.
    lowmower likes this.
  7. Aug 11, 2025 at 3:18 PM
    Schlappesepple
    Joe
    2020 4Runner ORP
    FYI, that little triangle you can see in your picture should be pointing at the wear bar.
  8. Aug 11, 2025 at 3:51 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I wonder how many practically good tires go to waste every year because people paranoidly replace them.
  9. Aug 11, 2025 at 3:55 PM
    slater
    San Diego
    As I sated, ide run that tire till its time to replace them....
    Which may be now, I want to see pics of the tread...
    That being said I also try & get the most out of my tires before replacing...
  10. Aug 11, 2025 at 3:59 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Probably ten times the number that blow out on the highway, and a hundred times those that blow out and cause a crash, and two hundred times those that blow out and cause a crash with a fatality.
    Citron likes this.
  11. Aug 11, 2025 at 4:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Idk but I've seen alot more questionable tires on vehicles than ones that were replaced as a precaution.
    Personally I'd rather have good tires than questionable ones, if it's 8-10 years old and/or looks questionable I'm replacing it unless it's on something that just get's driven around town or or offroad/county roads at low speeds.
  12. Aug 12, 2025 at 5:11 AM
    lowmower
    lowmower Well-Known Member
    Benji
    2011 Pyrite Mica V6
    When they're the only thing between your truck and the road I don't think its "paranoia" to be concerned.
  13. Aug 12, 2025 at 7:00 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Tires are almost 3 years old. If you drive an average amount of miles you're getting close to needing new tires anyway. I'd buy 4 new ones and have one of the other 3 moved to the spare. I always have the best old tire rotated to the spare position every time I buy new tires. If you can't afford 4 now buy 2 and put them on the rear. Buy 2 more within the next couple of months. LESS than 5000 miles down the road.
