Tire plug questions
Discussion in 'Wheels & Tires' started by Hook78, Jan 23, 2019.
  1. Jan 23, 2019 at 4:09 PM
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Got home from work, was inside for an hour or so, went to head back out. Had a low tire pressure light.
    Upon inspection found this bastard buried up to the hex head dead center in the middle of one of the rear tire treads.
    I fixed it with a plug kit. Didn't even have to dismount the tire. Inflated back to 32 PSI no problem, no hissing. I probably should have done a soapy water test.
    As an aside, how the HELL did this get in my tire? Nails I understand, but a screw this long? Anyway...
    What experiences do you guys have with plugs, how long do they last, etc? Should I expect the tire to be low again in the morning? Will it be safe to drive on at 60 mph to and from work? My gut instinct is to replace the tire at my first opportunity, probably in a couple days. They've only got a few thousand miles. However I'm wondering if it's even safe to drive on at highway speeds.
    Other options (other than a new tire) I suppose are to do nothing, or to have it patched. I assume running a plug long term is a really stupid, dangerous idea. What about a professionally installed patch, is that a permanent solution?
    I have the air compressor and extension cord in the truck, ready to do battle tomorrow...
    Appreciate your suggestions and advice.
  2. Jan 23, 2019 at 4:14 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You are fine. I used to work construction. I would get screws like that in my tires often. I plug and move on. The plugs last until I have worn out the tires.
    In fact, when I was getting a new set of tires the tech asked me if I knew there were 7 plugs in one of my tires? I told him "that sounds about right".
    photogr4x4, TomTwo and rob1208 like this.
  3. Jan 23, 2019 at 4:18 PM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    A plug is fine. Pep Boys does plugs if you get a nail or something similar. I have 2 in each of the rear tires that have been there for more than 15k miles. You'll be fine.
  4. Jan 23, 2019 at 4:18 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Ok well that's great to hear, thanks!
  5. Jan 23, 2019 at 4:19 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    3rd for plugs. I've done it on several tires and they last for the remaining life of the tire. A couple of those include multi-state trips. I actually just plugged one of mine this weekend. I would double check the pressure in a week just to be sure the plug held properly.
    koditten likes this.
  6. Jan 23, 2019 at 4:20 PM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    if you followed direction when you did the plug the location you said it was is actually the best location to use the string type plug, just make sure you trimmed it off even with the tread of the tire and you will be fine.
  7. Jan 23, 2019 at 4:23 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Yeah I trimmed it as best I could, I'm sure driving on it will even anything out. Pushed it in till 1/2 inch was showing, 1/4 twist and out. Couldn't believe how easy it was. Those damn things are super sticky.
  8. Jan 23, 2019 at 4:23 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Thanks for all the feedback, I will check the pressure in the morning and carry on.
  9. Jan 23, 2019 at 4:26 PM
    GHOST SHIP
    GHOST
    Give it a couple days just in case you have a slow leak. Also make sure to compare tire pressure in similar temperature. Hot tires will read higher pressure than cold because science.
  10. Jan 23, 2019 at 4:27 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Good point, temps here have been anywhere from 65 to 25 lately...
  11. Jan 23, 2019 at 4:28 PM
    GHOST SHIP
    GHOST
    I meant if you've recently driven vs the car has been sitting overnight as well.
  12. Jan 23, 2019 at 4:28 PM
    Wsteven
    2018 Tacoma TRD Pro
    Working on them
    From your Description you did it perfect, I have a plug I did on my Benz 2 years ago and it is still holding well, Only time the plug is iffy is when you get very close to the side wall then it Hot patch time. Anywhere in the road surface area is fine to the string plug.
  13. Jan 23, 2019 at 4:29 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Oh I gotcha, thanks for clarifying. Even better point.
    GHOST SHIP[QUOTED] likes this.
  14. Jan 23, 2019 at 4:32 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Funny thing is I had to take the screw out with a socket wrench. I guess that's not that funny but to me to be sitting there ratcheting a screw out of my tire....anyway. I thought that when it came out there would be a huge rush of air and then a completely flat tire...but that didn't happen. There was plenty of clearance to use the plug tools which was nice. Great system. I got the ones with the t-handles.
  15. Jan 23, 2019 at 4:48 PM
    Wsteven
    2018 Tacoma TRD Pro
    Working on them
    The "T" handles are the only way to go the ones with the screw driver handles are just cheap junk.
  16. Jan 23, 2019 at 4:49 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    It was damn hard even with the t-handles to get the plug in. I can't even imagine with the screwdriver handles.
  17. Jan 24, 2019 at 5:26 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Sorry to hear about the puncture - I know how frustrating they can be!
    Objects in the center of the tread are typically easily repairable as long as the object isn't greater than 1/4 of an inch.
    The plug, though, is not what actually holds the air in for a proper repair. That is there to keep water from getting in and rusting the internal steel belts. A patch on the inside is what keeps the air from leaking.
    For a proper repair, the tire should be dismounted so that the inner liner can be inspected and then if deemed repairable, a patch plug combo should be used.
  18. Jan 24, 2019 at 5:57 AM
    KactusJack
    KactusJack Well-Known Member
    Collettsville, N.C.
    2014 AC TRD Sport
    Hope I'm not thread hijacking here, but what can you guys recommend for a good-quality plugging kit?
  19. Jan 24, 2019 at 6:09 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    This is the one I used, it's what they had at the auto parts store. Worked great so far but I can only vouch for one day's worth of it holding up.
    https://www.oreillyauto.com/detail/...ab881/xtra-seal-tire-repair-kit/15005/4870356
    There are some on Amazon that come in a hard case which would be nice for a kit to keep in your truck.
    As discussed earlier in the thread, the t-handles are key.
  20. Jan 24, 2019 at 6:10 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Hey thanks for this, I wasn't sure whether I still needed to get it patched. I will probably go ahead and get that done this weekend.
