Tire Ply! Here we go again!!
Discussion in 'Wheels & Tires' started by TEX357, Mar 17, 2009.
  1. Mar 17, 2009 at 11:19 PM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    What tire ply are you all running? i was told that a 10 ply (nitto terra grappler) was too much for TACOMAS (Stupid in my opinion)? is this true(if it is whats the best ply to run on my tacoma)?
  2. Mar 18, 2009 at 2:37 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    10 ply is an E rated tire, you don't need to run an E rated tire on a Taco, but you can.
    It is going to be heavier which will lower your mpg slightly and it is going to be stiff, so your ride is going to be harsher.
    I'm running Nitto TG's, C rated in a 265/70/17.
    Just FYI in case someone doesn't know...
    B rated= 4 ply
    C rated= 6 ply
    D rated= 8 ply
    E rated= 10 ply
    F rated= 12 ply
  3. Mar 18, 2009 at 8:08 AM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    Dang thanks for the info. didnt know any of that!
  4. Mar 18, 2009 at 9:57 AM
    GASH
    GASH Well-Known Member
    Josh
    Albuqueruqe
    07 TRD 4x4 DC
    Fox 2.5" Remote Reservoir Coil-Overs, All Pro Expedition leafs with Fox adjustable shocks, Armor Tech Offroad Skids, NST Lite Weight Pulleys, WeatherTec Floor Liners, TRD CAI, Custom Decals, Wheelers Super Bumpstop
    I just ordered the new Wrangler DuraTrac's I got a great deal on them but they are a 10 ply. I hope they don't ride to harsh. Are any of you running an E rated tire? What do you think?
  5. Mar 18, 2009 at 10:44 AM
    GASH
    Josh
    Albuqueruqe
    07 TRD 4x4 DC
    I'm in Burque also where do you usually go?
  6. Mar 18, 2009 at 4:25 PM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    I would go with a D rating, E is a little much for Taco. When you go to air down a E rated tire it will not flex very good since the taco is on the lighter side. My D rated MTR's flex is good.
  7. Mar 18, 2009 at 7:28 PM
    GASH
    Josh
    Albuqueruqe
    07 TRD 4x4 DC
    I've done some trails near Socorro in Escondida. How do you get to the trails in the San Mateo mountains?
  8. Mar 19, 2009 at 3:05 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    285/70/17 Goodyear BFG KM2's, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    10-ply is way to stiff, and if your towing a 20ft. 5th wheel then they would be ideal. Each tire has a maximum Load capacity, that corresponds to the tires "ply". 6-ply is 1,000lbs. each tire, I believe. and 10-ply is like 2,300lbs for each tire. 6-ply is an excellent choice for Tacoma's since they are not that heavy. Unlike the Full size brother's, which usually run 8 or 10-ply tires. One more thing you should know. If you plan on ever airing down your tires i.e. in Sand, mud, off-road. Good luck getting flex out of the tires, or sidewall. The tires are going to be super stiff, due to the heavy ply.
  9. Mar 19, 2009 at 3:06 PM
    tacoma08MZ
    tacoma08MZ Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
    my nittos are 8ply i do beleive
  10. Mar 19, 2009 at 3:09 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    e tires are going to be brutal inflated to 35 psi.
    My old 89 4runner had e load 32.11.5.15 all terrains on it. lifted 3" it rode OK, but could have been better if I put say D tires on it.
    It all depends on how you use your truck.
  11. Mar 19, 2009 at 3:18 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    I have a set of 10 ply tires on my truck at the moment. If it wasn't for the fact I drive the truck on construction sites that have had the roadways mined, leaving sharp rock edges, I definitely would have went with some 6 or 8 ply tires.
    Not only does the tire cost considerably more, it will no doubt be more harsh of a ride than say, a 6 ply.
  12. Mar 19, 2009 at 5:02 PM
    GASH
    Josh
    Albuqueruqe
    07 TRD 4x4 DC
    Some of the initial reviews of the DuraTrac are that the sidewalls ride soft or even a little squishy. I guess well see since my tires come in tomorrow!
  13. Mar 19, 2009 at 6:31 PM
    GASH
    Josh
    Albuqueruqe
    07 TRD 4x4 DC
    I'll post up some tomorrow after the tires are installed.
  14. Mar 19, 2009 at 6:33 PM
    sbeau1960
    sbeau1960 Well-Known Member
    Scott
    Indianapolis
    09 Tacoma Double Cab TRD Sport Pyrite Mica
    Just put on C rated Bridgestone Revos today, firmed up the ride considerably from the stock BFG's but still not too harsh.
  15. Mar 19, 2009 at 6:39 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Ok forgive but...where are you reading the tire ply ratings at? On the tire itself?
  16. Mar 19, 2009 at 8:30 PM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    No. the LADY as talked about up in the beginning of thread.. told me that the nitto terra grappler i wanted was 10 ply? i haven't actually gone to the place to check them out but im going tomorrow, so well see!:confused:
  17. Mar 20, 2009 at 4:06 AM
    HerNameIsLucy
    RIP Lucy.
    I mean, where do you see the A, B, C, D etc tire rating? Is it on the side of the tire? If so, where?
  18. Mar 20, 2009 at 8:05 AM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    I personally have no idea, thats just what the lady told me, when you order them online you can always see the tire rating but as in visually see i wouldnt know!:(
  19. Mar 20, 2009 at 4:54 PM
    SC4333
    Grant
    San Antonio, TX
    You should be able to find the load range of your tires near the "max weight _____ @ __ PSI" marking. You tires should say "Load Range __"
  20. Mar 20, 2009 at 6:06 PM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    I just ended up going with the nittos in a 265\70-18:(
