Tire presser
Discussion in 'Towing' started by boxxed, Dec 4, 2013.
  1. Dec 4, 2013 at 8:08 PM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    Off Road
    Leer Cap Kenwood DNX 9140 Boyo back up cam HD Raido Sirius Weather Tech Mats Memphis Audio, Valentine One radar,Tinted windows,Wet Okole's, Bed mat.
    I have a 14 ' tandem axle trailer that is loaded up pretty good. I have an 09 dbl cab OR. I have have the leaf spring tsb done and I also added the Firestone Rite Ride bags installed.
    The towing weight is just about maxed out. What do tire pressure is good for the tires on the truck and trailer? Should I put it at max pressure per tire recommendations.
    Thanks
  2. Dec 4, 2013 at 8:13 PM
    302 I love Taylor Swift :D
    Lawrence
    302
    07' DCSB TRD Sport SSM
    Bedside decal
    No. Read sticker in door jam or read owners manual.
    3
  3. Dec 4, 2013 at 8:16 PM
    169.254.255.201 Well-Known Member
    Interwebs
    ^No.
    Chances are oP doesn't have stock tires, in which case those stickers aren't right for him.
  4. Dec 4, 2013 at 8:28 PM
    Lawrence
    302
    Bedside decal
    He should be able to answer his own question. I answered no to maxing out his tire pressure. Are you saying he should max them out then? Do you have an answer to the question(s)?
    3
  5. Dec 4, 2013 at 8:31 PM
    boxxed
    Denver, CO
    Off Road
    You are correct. I do not have stock tires.
  6. Dec 4, 2013 at 8:35 PM
    boxxed
    Denver, CO
    Off Road
    So what is a good range of pressure to be at? If I knew the answer I would not have asked for help. I have Continental CrossContact LX20 with EcoPlus on my truck.
  7. Dec 4, 2013 at 8:40 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    It should say on your sidewall the max pressure at what weight.
  8. Dec 4, 2013 at 8:40 PM
    Lawrence
    302
    Bedside decal
    I'm pretty sure you would need to increase tire pressure but what size tires? How much weight? How far of a tow? What size tires on trailer? Too much info missing to answer. That's why I said you should be able to answer your own question because you still have the info needed to resolve.
    3
  9. Dec 4, 2013 at 8:43 PM
    boxxed
    Denver, CO
    Off Road
    It does.. I belive it is 55 PSI.. I ll have to look and see if it says what weight.
  10. Dec 4, 2013 at 8:44 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Maxed out load, yes... max sidewall pressure.
  11. Dec 4, 2013 at 8:47 PM
    Lawrence
    302
    Bedside decal
    Or just listen to rich cause that dude knows much. :D
  12. Dec 4, 2013 at 8:48 PM
    boxxed
    Denver, CO
    Off Road
    OK I get it. The truck size is 265 70 16. Not sire of the trailer. The trailer is about 5500#
    I guess I was thinking the heaver the load the more tire pressure I needed and since I was basically at max load of the tow weight then I needed to be a max load psi on the tires.. I am going from MI to CO. (1300 miles) Pretty much flat land all the way. So I wanted to run it by far more knowledgeable people then I.
  13. Dec 4, 2013 at 8:53 PM
    Lawrence
    302
    Bedside decal
    I never thought it was a good idea to go all the way to the max in any condition but I'm sub'd for this one. We live we learn. Now that 5500# @1300mi might be a whole notha can o worms. :D.
    Good luck brosef
    3
  14. Dec 4, 2013 at 9:06 PM
    boxxed
    Denver, CO
    Off Road
    Yes indeed.. We shall see.. I have towed it around town to get an idea of what it will be like and it tows great. Those air bags make all the difference.
  15. Dec 4, 2013 at 9:07 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Max is there for a reason.
    And sidewall max is actually not the maximum safe pressure. It simply means that the tire's max load is attained at that pressure.
    Higher inflation reduces the likelihood of hydroplaning, reduces tire heat, which extends life and reduces treadwear.
    This is within reasonable levels.
    Going too high CAN lead to wearing the center of the tire, but in 30 years I've never seen it on any of my vehicles and I've always run at sidewall max.
    Only drawback is the ride is rougher.
    If you drive offroad, you'll want to air down for flotation on sand and rocks.
  16. Dec 4, 2013 at 9:17 PM
    boxxed
    Denver, CO
    Off Road
    Thank you.. I am just asking this PSI question just to get me from point A to point B. Once I get there I will go back to what I have the PSI set at now.
  17. Dec 5, 2013 at 5:43 AM
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
  18. Dec 5, 2013 at 5:59 AM
    boxxed
    Denver, CO
    Off Road
  19. Dec 9, 2013 at 7:05 PM
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB
    I ran max, 80 psi on my old sets and got 60k on a 7500# dodge diesel.
    Never had a problem on both trucks over 300k on the two trucks, all at or about max.
  20. Dec 10, 2013 at 6:55 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    13 Access 4x4 TRD Offroad
    Empty gas tank mod
    I run my truck tires at max PSI for highway driving and my trailer at max PSI as well. Tires last a long time and seems to tow great. Have always done it that way, I have 5 trailers that I tow, 2 snowmobile trailers, 2 boats, and a utility. None are 5500# just for the record, nothing much over 2500#.
