Tire Pressure and gas
Discussion in 'Wheels & Tires' started by surfsupl, Jun 29, 2008.
  1. Jul 6, 2008 at 7:34 PM
    #41
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Tim, what you are saying is that if you have a Tacoma, and add 33" tires, because Toyota recomends 26 psi in the tires, 26 psi is good for the new LARGER tires?
    The Chalk method is still more accurate.
  2. Jul 6, 2008 at 7:58 PM
    #42
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Shoot the placard on mine says 26-NO WAY! I did it ONE TIME and my tires were sloppin all over and my truck felt like it was a lil slower! I swear I think they put a lower # so the ride on our trucks will be a little softer.
  3. Jul 6, 2008 at 8:01 PM
    #43
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Excatilly. On a bone stock vehicle, with the stock smaller size tires, maybe. Once you start adding things like a topper, larger tires, tools, gear, etc., with the added weight, and larger tires, the placard on the door jamb is void. :)
  4. Jul 6, 2008 at 8:14 PM
    #44
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    95% of the people here probably changed their tires to a different size
    Being that it is recomended that tires be checked when cold, that is precisly why you do the chaulk method when cold. Honestly, when dealing with air psi and temps, how practical is it to pull over and adjust your air psi every few miles as the temps go up? Everybody says to only check your tires WHEN COLD. And useing a tire chart its a fine baseline. BUT, many tires that fit a 7500 lbs. rig ALSO fit a 4400 lbs. rig. Is the psi for the larger truck aplicable as its the same size as is being used on the smaller one?
  5. Jul 6, 2008 at 8:16 PM
    #45
    Ridgerunner
    Frank
    Rocklin, Ca.
    +1! If you are adjusting for hot tire pressure you will be refilling your tires every morning to do it all over!:eek:
  6. Jul 6, 2008 at 8:20 PM
    #46
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    True! LMAO.
  7. Jul 6, 2008 at 8:37 PM
    #47
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Here we go again. lol. I like getting all the different perspectives.
  8. Jul 6, 2008 at 8:43 PM
    #48
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :D
  9. Jul 7, 2008 at 10:20 AM
    #49
    Ridgerunner
    Frank
    Rocklin, Ca.
    I got ya timmer-but they refer to the mass of air that has not expanded due to 'heating up' from use inside the tire as "cold". They aren't referring to the ambient outside temperature.
