Tire Pressure Check Engine Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wilsonpj, Jun 14, 2009.
  1. Jun 14, 2009 at 3:02 PM
    wilsonpj
    wilsonpj [OP] Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    Anyone know anything about a broken sensor that monitors the tire pressure. Sensor is broken needs replacing. CEL is flashing.
    Where is the sensor located? How much for a new one? etc..?
    Thanks
  2. Jun 14, 2009 at 3:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If the Check Engine light is flashing, you have a different issue. Go have the code read.
  3. Jun 14, 2009 at 4:26 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah....Go to autozone or whatever and get them to pull the code. Post it up and go from there.
    If it is a TPMS sensor- Then it's in the tire and you got to the dealer for them.
  4. Jun 14, 2009 at 4:37 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    TPMS and Check Engine light are two different things.
    This is the TPMS fault light
    Below is the Check Engine light - If you have this lit up, you need to go to Autozone (or dealer) and have them pull the fault codes out of the computer. Report back to us and let us know what you find out.
  5. Jun 14, 2009 at 5:00 PM
    98tacoma27
    Ben
    Not Beech Creek
    The CEL doesn't blink. The TPMS light will blink if you have a bad sensor on one of the tires. They are located in the vale assembly. You will have to go to the dealer in order to fix it.
  6. Jun 15, 2009 at 8:34 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    It is the TPMS. It is flashing. It is on a truck I am looking at buying. The seller said he would look into what the issue is and let me know.
    I'm just trying to do my homework.
    He had stated that one of the sensors was broken and needed replacement.
  7. Jun 15, 2009 at 8:37 AM
    98tacoma27
    Ben
    Not Beech Creek
    That sounds legit. At least he is beiing honest with you. If the light is on solid, that means one of the 5 (yes, including the spare except on the 09's) is low on air. On the drivers side door is a sticker that tells you what the presurres need to be at. Those are the minimum pressures for the sensors. Of course, use your tire manufacturer recommended pressures.
  8. Jun 15, 2009 at 9:33 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    Any ideas on cost, time, effort to get it fixed?
  9. Jun 15, 2009 at 9:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    No clue. It is a dealership thing. It is really not a huge concern unless the blinking light bothers you.
  10. Jun 15, 2009 at 11:48 AM
    Janster
    Jandy
    Lancaster, PA
    As far as I know, it's part of the valve/valve stem.
    You'll probably have to dismount the tire, remove the old sensor and put in a new one, remount the tire and probably have that tire rebalanced.
    Definately tell that guy to get that fixed BEFORE you commit to buying the truck.
  11. Jun 15, 2009 at 12:44 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Sorry for a partial thread jack, but my sensor has been on since I bought it over a year and half ago. All the tires are inflated to proper spec including the spare. However the spare is a different tire and thus inflated to a different pressure. Do all the tires need to be at the same PSI or do they all have to be at the door jam recommended PSI to get rid of this fucking light?
    I've tried everything including resetting the tire sensor thingy.
  12. Jun 15, 2009 at 2:26 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I would assume so. If all the sensors are the same throughout the system, then they would have to be. The sensors however, are nothing more than switches. Get a different sensor that switches at a different pressure and maybe you have a solution... who knows?
  13. Jun 15, 2009 at 3:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    The ECU needs to be reprogrammed with the new sensor.
  14. Jun 15, 2009 at 3:57 PM
    Janster
    Jandy
    Lancaster, PA
    It's an FM transmitter/receiver type system right? So, would that mean the new sensor has its own frequency the ECU has to 'learn'?
  15. Jun 15, 2009 at 4:25 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    What I have been told is each sensor has a code that is programmed into the tpms ecu, if yours breaks and gets replaced the old sensor code needs to be removed and the new one inputted via a special tool. The ecu only can store 5 codes in the case of 06-08. Not sure about the 09s since they only have 4 sensors guess they get a free pass on one code? :confused:
    The codes are stamped on the black butterfly looking thingy that hangs out on the other side of the valve stem inside the tire. You gotta remember to write down these codes for they are not recorded anywhere so I'm told. :rolleyes:
    To a point imo its a racket, 4 of my sensors are on my steel wheels/winter tires stored under a tarp in the backyard. Spare sensor is still in place. Alloys with no sensors are on truck. As long as I stay "in range" more or less 40ish miles no light. After that blinky light. One of Neon's Tacomaworld business cards fits perfectly covering up the idiot light until it resets on its own in my driveway.
    Good luck to the OP have seller fix on their dime!
  16. Jun 15, 2009 at 6:46 PM
    medic2230
    Murph
    Bama! Roll Tide
    Trust me it does blink. That's when you need to see what the hell is causing it then. Mine did it with misfire in multiple cylinders. Was on solid with misfire in a single cylinder.
    Murph
  17. Jun 15, 2009 at 6:47 PM
    98tacoma27
    Ben
    Not Beech Creek
    I think that is the first time I have ever heard that. Thanks for the info.
