Tire Pressure Deviation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2021SR5V64WD, Sep 2, 2023.
  1. Sep 2, 2023 at 11:27 AM
    2021SR5V64WD
    2021SR5V64WD [OP] Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    So there are times when all 4 tires are the same pressure but depending on
    riding in half-shade and 165 degree pavement one or more will get outta whack
    with the others.
    At the end of the day they'll all come back around the same all the way around.
    But at what point do you bring a tire up to pressure -
    Off by 3 pounds?... 4 pounds?... 5 pounds?
    Should I think about % ?
    Off by 5%.... off by 10% ...?
    Do I have too much time on my hands?
    hiPSI likes this.
  2. Sep 2, 2023 at 11:31 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Check your tire pressure when cold it will give u the most accurate reading . Tire pressure typically drops 1-2 pounds per a month and u will see tire pressure fluctuate with heat totally normal .I usually run 2-3 pounds over recommended tire pressure to allow for pressure change .
  3. Sep 2, 2023 at 11:33 AM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    Check them after they you have not driven for 3 hours and in the shade. They normal go down in the winter and up in the summer due to change in temperature.
    Rusty66 likes this.
  4. Sep 2, 2023 at 11:35 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Maybe I am a little OCD, but I will try to get all 4 PSIs around the same when all tires are cold. I like to keep PSI around 34-35 cold and will adjust when necessary. All 4 tires generally stay within 2 PSI on my combo meter and I am fine with that.
    Kolohe07 and WinterFalco like this.
  5. Sep 2, 2023 at 11:37 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’ve been driving since the 1980’s and I’ve never worried about air pressure until a tire was visually flat, but I also didn’t wear a bicycle helmet and I rode in the back of pickups. It’s amazing gen x survived to birth another generation.
    Excuse my grumpy old man complex.
    On a more serious note, (although what I said before is mostly true) my tire pressures between tires never vary by more than 3 psi, but I also air down/up relatively often and also carry a decent analog air pressure gauge. I think larger variations are not going to kill you, but if it gives you peace of mind, keep them in closer tolerances.
    I think the industry invented TPMS not for thinking responsible people like you, but for people that let air pressure decline over years to the point that it is a danger to us all.
    Toolndie7, 02Duck and bkhlrTaco's like this.
  6. Sep 2, 2023 at 11:37 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Funny timing that you created this thread. I’ve been playing around with my tire pressure and this morning I checked cold tire pressures. I noticed that two tires that had the same cold pressure yesterday had different pressures today. The tire that was in the sun was 3psi higher than the tire in the shade.
    They evened out again after a bit of driving.
  7. Sep 2, 2023 at 11:43 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Heat does funny things. Just check them in the morning and make sure they're set at or close to the recommended cold pressure (depending on if it's a warmer night than usual or not). Then don't worry too much about the little changes between each tire.
  8. Sep 2, 2023 at 12:16 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I check mine once /month or so. Check when vehicle hasn't ran for at least couple hours and in the shade. Adjust if off +- 4 to 5 lbs. Usually only 1 or two off but here there are seasonal changes for winter/summer. Sometimes 1 tire only will be off by 4-5. Try not to over obsess about tire pressure and oil level.
  9. Sep 2, 2023 at 12:19 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yes. Every 11 degrees temp increase raises the pressure by one psi.
    You have zero control over it. But, temp would have to change 77 degrees ( remember it's the air temp, not surface temp) to cause any real issue. Set it at 30-32 and don't look at tire pressure unless your bed is fully loaded with wood and you have a 6K trailer with 800 lbs on the tongue. Then you have friction artificially raising temps which raises pressure.
    Go back to sleep, content with the knowledge that smart people got you covered lol.
    Chew likes this.
  10. Sep 2, 2023 at 12:43 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Guess I may be older than you. I checked tire pressure occasionally with an old fashioned pencil gauge. Bicycling helmets were not heard of when I pedaled around town. We all rode in the back of pickups and my mom used to collect all the kids in the neighborhood with my dad's dump truck to go to the swimming hole - we all rode in the back. Seldom wore a helmet when putting around on my Harley (unless the state law required it). Boomer here that survived nonetheless, despite the age 18 drinking restriction and the advent of weed and other stuff in the 60s & 70s. We just never got really stupid.
    You think you've got a grumpy old man complex?!
    BTW, it wasn't the industry as much as it was the government that started requiring TPMS (for the lazy & ignorant).
  11. Sep 2, 2023 at 1:42 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    TPMS away the result of under inflated tires in the original Ford explorer. Rollover accidents and deaths. No one ever checks their tire pressure. It’s never my fault.
    as a responsible driver you should.
    02Duck and Patch Barracks like this.
  12. Sep 2, 2023 at 1:56 PM
    canuck guy
    Alberta
    23TRDOR
    I had a 4 door Explorer and a Bronco. The only way they could roll over is if you didn't know how to drive or were driving stupid.
    hiPSI and TacoManOne like this.
  13. Sep 2, 2023 at 2:02 PM
    Bishop84
    Bishop84 Well-Known Member
    As long as you stay over cold pressure and under max, you're better off than 80% of other cars on the road.
    Set the pressures in the morning to cold and be done with it.
    I set 4psi over on customers vehicles during the day in the summer. I set 1-2psi higher during the day in the winter.
    RustyGreen, hiPSI and Chew like this.
  14. Sep 2, 2023 at 2:20 PM
    2021SR5V64WD
    After going round and round with various gauges I've decided the old pencil gauge is by far the most stable but my current one just
    sprang about 30 feet away so I'll pick up another 2 or 3.
    I'm well aware of cooler weather playing games with pressure as well as hotter than hot.
    I think what I was looking for here and got is that anything 3 pounds or more top it up.
  15. Sep 2, 2023 at 2:23 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Three psi is the rule of thumb between hot and cold but you should adjust them cold and in the shade. If one side of the truck is facing the sun the pressure will be higher in that side.
  16. Sep 2, 2023 at 4:50 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Funny my motorcycle manual clearly states to check tire temperature when tires are cold and in the shade. I have always done the same with all my vehicles never had an issue and I never care what my tps says after I have started driving.
    Clearwater Bill and Road_Warrior like this.
  17. Sep 2, 2023 at 7:41 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    That's because 33 degrees is nominal difference between high and low temp of the day. Read my post. Re read my post. It's not hard to science.
    RIX TUX likes this.
  18. Sep 2, 2023 at 8:04 PM
    TerdFergy
    TerdFergy Active Member
    20 TRDOR MT
    Toytec 2.5 coilovers
    Check when you haven't been driving and in the shade, don't over think it.
    RIX TUX likes this.
  19. Sep 2, 2023 at 8:08 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Check your tires with a good calibrated tire gauge. That’s the pressure you go by. Use the tpms to tell you if there is a leak.
    Don’t worry about the pressure as you’re driving. Tires at speed need more air than at rest. They make heat at speed so they self regulate up and down as they heat and cool. Check when cold and don’t worry about it.
  20. Sep 5, 2023 at 3:35 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I run nitrogen in all my vehicles. When my Tacoma was new I always got a TPM light because of low pressure when cold outside. Never again with nitrogen as it set to 29 cold it gets to 31 maybe 32 on a hot day and cold days are never an issue. Some say its snake oil but for the past 10 years all my tires get nitrogen.
