Tire pressure for 265/70/17
Discussion in 'Wheels & Tires' started by Nashwaak1, Oct 14, 2016.
  1. Dec 3, 2016 at 3:26 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    265/70r17 (+1" over stock) is the largest size tire you can run while stock with no issues. You'll likely have to remove your front mud flaps to avoid rubbing, but that's it!
  2. Dec 3, 2016 at 3:28 PM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    I did not. The little front flap thing rubbed when bottomed out and turning but that's it.
  3. Dec 3, 2016 at 3:30 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm guessing you have stock wheels? Usually the only ones who rub the front flaps have aftermarket wheels that are pushed out farther than stock.
  4. Dec 3, 2016 at 3:30 PM
    randomguy
    The Dalles, OR
    17 T4R 4x4 MGM
    Yep stock wheels. That makes sense.
  5. May 30, 2017 at 10:40 AM
    sparker
    sparker Well-Known Member
    Scott
    Southern California
    '17 TRD Sport 4x4 A/T DCSB MGM
    >Matte Black 4Runner TRD Pro Wheels + 265/70/R17 BFG KO2s >TRD Pro Grille >Black Tailgate Decals >MGM Door Sill Decals >MGM Glove Box Decals >20% Tint All Around >Toyota OEM Bed Mat >Debadged (V6 and Tacomas) >Center Console Tray >Center Console Organizer >Visor Warning Label Decal Stickers >Front Bed Rail >10 1" D Rings Around Bed Storage Compartments >Kicker Subaru Tweeters >Rear Mudguards
    I just put on 265/70/R17 BFG KO2s C Rated on my 2017 DCSB and was battling over what PSI to use. When I emailed BFG all my details, they said I should be running 45 PSI on front and back. I've seen other TW users post similar responses from BFG. Anything over 40 still seems high to me but wouldn't the tire manufacturer know best? IDK.
  6. May 30, 2017 at 10:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No, they would not. You're right in that that's a high pressure. Try running 33 front and 31 rear and see how you feel. If you want to definitively know, google the chalk test.
    sparker[QUOTED] likes this.
  7. May 30, 2017 at 11:39 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    38 front 35 rear worked best for mine.
  8. Jun 1, 2017 at 7:52 AM
    Nateclimb
    Nateclimb Well-Known Member
    UT
    15 Inferno Pro SC'ed
    I have a 13 Baja (pro) and the sticker on the door says I should run 46 front and rear. The truck came with KO 265/70r16 load C, I now have an E rated tire but have no idea what to run the pressure at. I am looking for mileage not comfort.
    Would love any advise.
  9. Jun 1, 2017 at 8:02 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The trade off with that is if you pump up the pressure to get increased mileage, your tires will wear unevenly. Don't know if you'd save money in the long run since you'll likely have to replace your tires sooner.
