Tire pressure for 285x75x16?
Discussion in 'Wheels & Tires' started by Hydrounit32, Dec 9, 2017.
  1. Dec 9, 2017 at 12:25 AM
    Hydrounit32
    Hydrounit32 [OP] New Member
    Tom
    02 Toyota tacoma
    4 inch lift with 285x75x16 10 ply tires.
    How much tire psi should I run in 285x75x16 10 ply tires on my 2002 Toyota Tacoma? It has a 4 inch lift in it and rides like a tank! Thanks for any input
  2. Dec 9, 2017 at 12:54 AM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    When I worked at the tire shop we recommend 32 psi in all the smaller trucks and SUV's,
    That what I run in the 285's on my toyota.
    DustStorm4x4 likes this.
  3. Dec 9, 2017 at 12:56 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Chalk test it. But typically 32-35psi.
    303tacoma likes this.
  4. Dec 9, 2017 at 6:26 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! Also check the sidewall of the tire. Sometimes they have the recommended PSI on there.
  5. Dec 9, 2017 at 6:35 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    I second chalk test
  6. Dec 9, 2017 at 8:20 AM
    jadatis
    jadatis Well-Known Member
    Peter
    Your 10pr/E-load tires have maxload of 1750kg/ 3850lbs? AT 80 PSI . But check this on sidewall.
    Your rear gross axle weigt rating is probably lower then that. So advice pressure will come to lower then half of 80 psi so 40 psi.
    So I can imagine that with 80 psi filled your ride will be verry hard.
    I can calculate the needed pressure for you, but need best real weight on sepetate wheels, but GAWRs will do.
    The official formula comes to lower pressure, but you can add 10% to the weights and calculate lineair.
  7. Dec 9, 2017 at 10:48 AM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Tire shop put 40psi in mine, too damn much... it was stiff as shit. I’ve aired them down to 36 and still may go lower, need to chalk them.
