Tire pressure for even wear and comfort
Discussion in '4th Gen. Tacomas (2024+)' started by slater, Nov 20, 2024.
  1. Nov 21, 2024 at 5:22 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    This is as far as you need to go to see the tech doesn't know what he's talking about. He's admitting to over-inflating tires to reduce wear on the outside edges, while also claiming this promotes even wear. Not only is this a bad idea, but what he's doing doesn't even match what he says. (Also why you should always verify your own tire pressure).
    The chalk test will give you the optimal pressure for even wear for the exact conditions when you do the test (likely unloaded, driving on a straight, level street), but not necessarily performance.
    The load calculation Falken did matches the design load between the two tire sizes (which is driven by, but kind of independent from the vehicle weight). This should be safer and would cover all of your bases. I would also hold the opinion from a tire manufacturer over most other sources, when it comes to tire settings and performance.
    Vidman likes this.
  2. Nov 21, 2024 at 5:43 AM
    PondScum
    PondScum OG 303
    Colorado
    2023 Trail Edition
    6112/5160, Deaver J66, Wildpeaks, OTT, Sliders, Armor
    Here’s using the original load method (the “Falken” method). Chalk test also is helpful, but as pointed out may not agree with OEM specs.
    (The on the same site is useful when considering new tires.)
  3. Nov 21, 2024 at 7:33 PM
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
    24 off-road here, door stickers say 30 psi stock for the 265/70/r17s.
    I got 285s and my tire shop had them up to 45 psi.
    I deflated down to 30.
    I totaled a Honda accord on a wet curvy road because I had just swapped out my summer tires and the winter tires were at 50 psi. They were like ice skates. No traction on the curve and I flew straight into a wall. Overinflated is dangerous.
    Schlappesepple likes this.
  4. Nov 22, 2024 at 5:59 AM
    slater
    slater [OP] Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Very interesting to hear the off-road tire pressure door sticker is actually 30psi also....
    Havent drove the truck last few days, need to get her out of the garage & bring her down to 30psi,
    That should really improve the ride quality...
    Just dreading me setting them to 30 & then the TPS's read something else due to inaccurate tire pressure gauge most likely....
  5. Nov 22, 2024 at 8:48 AM
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    I was taken back when I saw the recommend tire pressure by Toyo is 30 psi for these large tires. My 2 cents - it's strictly for comfort. I generally keep mine higher, at 34psi for load and towing. Keep in mind, the lower the tire pressure the less mpg...
  6. Nov 22, 2024 at 8:50 AM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    Any time anyone else touches your tires you have to check them. Took mine to the dealer for the 5000mi checkup and they noted on the checklist that spec was 30 psi. Then proceeded to inflate them to 36.
    I had 3 different pressure gauges (2 on inflators and one dial gauge) that all read differently so I bought another gauge that was "certified". It matched my existing dial gauge. When I inflate to 30-31 psi the TPS reads 28-29.
    www.amazon.com/dp/B015HURK64?ref=ppx_yo2ov_dt_b_fed_asin_title
  7. Nov 22, 2024 at 9:15 AM
    slater
    San Diego
    Looks like a quality brand so not knocking it by any means...
    That being said, my tps display, all 4 tires read right on the money compared to what DT told me they set them at...
    meaning accuracy of tps & actual pressure in the tire was on-point, so ide still question the accuracy of your gauge..
    Quality brand but still only $20 & reading through the reviews theres plenty of people claiming inaccuracy, even compared to a reference gauge.
    Ide question hands down accuracy of that gauge before questioning accuracy of tps's..
  8. Nov 22, 2024 at 10:09 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  9. Nov 22, 2024 at 12:21 PM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    A couple of days after I got my TRD Sport and was playing with the dashboard gauge settings, I noticed the tire pressure monitor was reading 38psi for three of the tires and 39psi for the fourth. My tire pressure gauge confirmed the readings the truck reported. Seems my experience mirrors the others' whose tires came way overinflated. Being that high made me concerned that the pressure on the highway on a hot day could exceed the maximum pressure the tire is rated for.
    I set them all to 32 like the sticker says. My immediate observation was that it rode much better. Even my wife, who usually isn't tuned into such things, said something the next time she drove it.
  10. Nov 22, 2024 at 12:36 PM
    Schlappesepple
    Joe
    2020 4Runner ORP
    Good time to note, make sure everyone is adjusting / setting tire pressure when the tires are cold (i.e. the vehicle hasn't been driven in at least 3 hours). Best time is first thing in the morning before you go anywhere.
  11. Nov 22, 2024 at 12:37 PM
    Schlappesepple
    Joe
    2020 4Runner ORP
    The pressure ratings take heat gain into consideration, max pressure on the tire is meant as max cold pressure (usually stated as such).
    treyus30 likes this.
  12. Nov 22, 2024 at 12:42 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Even if that wasn’t the case, a 45 psi max tire doesn’t pop at 46 psi. It just means 45 is where it stops gaining speed or load capacity. It doesn’t mean the tire is about to bust if it goes over X psi listed on the sidewall.
    PEAKIT likes this.
  13. Nov 22, 2024 at 2:47 PM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    I want to say someone did a chalk test on here or the 4g forum and came out to around 30 PSI, I just run 32 in the front and 30 in the back
    Vidman and hemlockz like this.
  14. Nov 23, 2024 at 1:59 AM
    Taco001
    Taco001 Well-Known Member
    24 OR
    The issue i have with the specified 30psi is that now its getting cold, my low tire indicator lamp comes on in the morning when ambient temp drops below 30F. I found out the tpm system alarm is 28psi. So i run mine at 32psi at about 40F. Temp sure does have an effect on tire pressure.
  15. Nov 23, 2024 at 2:04 AM
    #35
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Tire pressure is related to tire size and weight of the vehicle. It's pretty simple really. Just consult a chart and go with the tire pressure for your specific tire size and the actual weight of your vehicle.
    Here's one if you can't find your own: Application of Load Inflation Tables Version 2020-7
    There is no magic psi for all tires. Proper psi is related to tire size and weight of vehicle.
    Oh yeah, that door sticker is only for the actual tire size listed and the vehicles GVWR. It's for people who can't look at a chart and determine the correct psi for their application.
  16. Nov 23, 2024 at 5:19 AM
    #36
    soupy1234
    Low pressure light should not come on until the pressure drops by 25% or more. Adjust your pressure to what you want and reset the TPWS setting pressure.
  17. Nov 23, 2024 at 6:24 AM
    #37
    JC 4th Gen
    JC 4th Gen Well-Known Member
    Raleigh, NC
    2024 TRD Sport
    I also noticed the large pressure swing with the cold mornings, and had the TPS indicator on a few times...
    I was at Costco yesterday and noticed there was a tire inflation station at the service bays, and the air hoses were green. The green hoses caught my attention and sure enough, it is a nitrogen fill station - free to use for Costco members.
    I always thought nitrogen fills were a joke, but now I might air down and refill with nitro. I am curious to see if it really makes that big of a difference. Hey, it is free... :)
  18. Nov 23, 2024 at 5:29 PM
    #38
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    Just put sport wheels and tires on my SR5. I assume I need to drop the pressure down to what the sport runs, correct?
  19. Nov 23, 2024 at 5:32 PM
    #39
    slater
    San Diego
    Im in San Diego...:rolleyes:
  20. Nov 23, 2024 at 5:34 PM
    #40
    slater
    San Diego
    Ide say so, 32psi...
    What tires, the general grabber 265 65?
    Smooth running tire!
