Tire pressure for even wear and comfort
Discussion in '4th Gen. Tacomas (2024+)' started by slater, Nov 20, 2024.
  1. Nov 23, 2024 at 6:45 PM
    #41
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    Yes. I’d rather had the Michelins, but the price was right. I’m finally rid of those horrid SR5 wheels.
  2. Nov 23, 2024 at 6:51 PM
    #42
    slater
    slater [OP] Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    I powder coated. The TrD sport wheels sat in black for roughly $350..
    Originally that wasn’t the plan, but I said why not.
    Before this truck, I had a 24 SR5, and that was the plan all along powered coat the stock SR5 wheels black,
    I personally think they look the best out of all the trims….
  3. Nov 23, 2024 at 7:07 PM
    #43
    Wire4Money
    Tim
    I’ve seen the SR5 wheels powder coated, and they do look good. I may do that long term.
  4. Nov 23, 2024 at 7:58 PM
    #44
    slater
    San Diego
    Theres literally over 20 powedercoat shops in my town in san diego...
  5. Nov 23, 2024 at 8:11 PM
    #45
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    So how should it be calculated? I run my stock wranglers lower than sticker, especially in the rear unless I do a heavy load then I air up. Gonna do the chalk test ( I know Im a bit too low, but also mount and run over obstacles hence the 32psi).
  6. Nov 23, 2024 at 8:21 PM
    #46
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Using a tire pressure calculator. It takes what the tire can carry in stock form at the door sticker PSI and then calculates where the new tire needs to be to maintain that. the only flaw in this method is when the manufacturer states too high of a pressure to begin with. Like some of the manufacturers who basically say 35 psi no matter what.
    TheWildMan[QUOTED] likes this.
