Tire Pressure for load
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Greenbean10, Nov 14, 2024.
  1. Nov 14, 2024 at 10:21 PM
    Greenbean10
    Greenbean10 [OP] Well-Known Member
    2010 Timber Mic 4x4
    Hello TW,
    stupid question, but I will be traveling with some weight in my 5ft bed truck and was wondering if I need to increase my tire pressure. Will properly have 200lbs in the bed and maybe 250 lbs give or take in the cab including myself. Current pressure is about 30 psi cold I believe. Also, would I increase all four tires? Thanks!
  2. Nov 14, 2024 at 10:31 PM
    SamS
    SamS Well-Known Member
    Vancouver Island, BC, Canada
    06 Access cab 4x4
    I’d say don’t worry about it. That’s nothing, Imagine a typical 5 seater sedan with average(?) 150 pounds per person. They’re not going to be topping up the tires.
    Good question, though, and I look forward to other’s opinions. I only top my tires when getting closer to max GVW. And then maybe an extra 5 or 8 lbs.
    Greenbean10[OP] likes this.
  3. Nov 14, 2024 at 10:31 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The pressure shown on the doorjamb label is for vehicle loaded to GVWR. All the govt handling tests and stability control calibrations are done for GVWR.
    Theoretically you should be running a lower pressure when the truck is empty.
    HWI and Greenbean10[QUOTED][OP] like this.
  4. Nov 14, 2024 at 10:57 PM
    Greenbean10
    2010 Timber Mic 4x4
    This is a good point. Thank you
  5. Nov 14, 2024 at 10:58 PM
    Greenbean10
    2010 Timber Mic 4x4
    Awesome. Thank you
  6. Nov 15, 2024 at 6:43 AM
    hinmo24t
    hinmo24t MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    i run 35lbs give or take in mine for many years! 32/30 is a lot more comfy but i notice some weird tread wear with lower psi (same can be said for too high) but lower constantly i see scalloping
  7. Nov 15, 2024 at 4:26 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I like to run closer to 35 PSI all the time. That way I don't have to add air when carrying a load and then let it out after. But for that small amount of weight you'll be fine. Payload on most Tacoma's is 1000-1200 lbs. If you were close to that max, then adding few PSI would be a good idea.
  8. Nov 15, 2024 at 4:49 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I run 29 all around no matter how much I load it down. I do have airbags so when the back is loaded full of firewood and I'm towing my trailer with the side by side, I put 30-50 lbs in the airbags.
  9. Nov 15, 2024 at 6:17 PM
    Greenbean10
    2010 Timber Mic 4x4
    Is that 35 cold psi?
  10. Nov 15, 2024 at 6:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Adding PSI past 30 on standard tires doesnt change load capacity, but it does make the truck feel less squishy.
    I always recommend 5 psi more on standard load tires when hauling or towing.
  11. Nov 15, 2024 at 6:21 PM
    Greenbean10
    2010 Timber Mic 4x4
    Sweet! Thanks
  12. Nov 15, 2024 at 6:37 PM
    trexgrrr
    trexgrrr Well-Known Member
    The weight you’ll be traveling with isn’t a ton. No need to bump up the psi, but if you really wanted to, 2-4 psi won’t hurt.
    ridefreak likes this.
  13. Nov 17, 2024 at 6:27 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I was running 32psi most of the time, overall the ride was better compared to 35psi which I've run before. After adding the weigh of a topper and mid sized tool box in the bed (easy 200#) the recall springs were insufficient, yeah it worked but had a bro lean and the HL pointed upward. I went back to 35, swapped the rear springs and the ride didn't feel harsh like it did previously when I ran that pressure, the stance was correct and I like the way the truck handles the extra weight with the springs and higher pressure. Incidentally my truck has been getting some of the best mileage of it's career with those changes and some minor motor stuff. I attribute most of that to the aerodynamic changes of the topper and the extra tire pressure. I have no plan to go back, the current setup feels far more dialed in to me.
  14. Nov 17, 2024 at 7:05 AM
    skee
    skee Well-Known Member
    North Coast, CA
    2006 Tacoma TRD 4x4 Access Cab
    Which springs did you go with? And are you running the stock shocks?
  15. Nov 17, 2024 at 2:29 PM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    5100s and the HD springs from general.
    skee[QUOTED] likes this.
