Tire pressure for towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VA Tacoma, Aug 9, 2015.
  1. Aug 9, 2015 at 12:20 PM
    VA Tacoma
    VA Tacoma [OP] Well-Known Member
    Frank
    Roanoke, VA
    08 AC 4x4 SR5 off road 4.0 super white
    bone stock
    I read the towing bible and saw no mention of tire pressure. Just keep the recommended pressure for all applications?
    Thanks
  2. Aug 9, 2015 at 2:36 PM
    mike2810
    mike2810 Well-Known Member
    Arizona - Rim Country
    had 06 Sport 4x4 , now 2016 Nissan Pro 4x
    Don't exceed the max cold listed on the side of your tires. You can add up to that amount depending how heavy the trailer is.
  3. Aug 9, 2015 at 6:38 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    When I'm towing a small trailer or bass boat, I leave them at 35. When I towed my TT, I aired up to 40 rear.
  4. Aug 9, 2015 at 7:41 PM
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
    I follow the door jam pressures 29 front, 32 rear. I'll be towing a tandem axle 6x12 with a large garden tractor with 5 attachments. Does 40psi sound right?
    Thanks
  5. Aug 9, 2015 at 8:40 PM
    Black Taco
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    That's what I would go with towing that. Equally as important, make sure your trailer tires are aired up properly.
  6. Aug 10, 2015 at 4:23 AM
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
    Thanks, I will be towing about 1300 miles so I want to get it right.
    Thanks again.
  7. Aug 10, 2015 at 7:28 PM
    Black Taco
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Safe travels.
