Tire Pressure Gauge, Which Is The Best.
Discussion in 'Garage / Workshop' started by eurowner, Feb 15, 2019.
  1. Feb 15, 2019 at 3:06 PM
    eurowner
    eurowner [OP] Duke Sky
    Scoty
    My 30+ year old trusty accurate Blue Point dial tire pressure gauge died a horrible death. I drove over it. It was accurate with my 3rd Gen display tire pressure. I have been in happy with a lot of gauges that I have got, and returned due to inaccuracy.
    What ones do y'all like and trust?
    Thanks for the help.
  2. Feb 17, 2019 at 3:05 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have had a Milton one now for 20 plus years
  3. Feb 17, 2019 at 4:11 PM
    eurowner
    Scoty
    Thanks!
    I have one as well and it's not accurate.
  4. Feb 18, 2019 at 12:25 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Then you must be working to a finer degree then I have ever done
    If it reads within a few pounds at 100 psi close enough for me .
    You might want to look into science grade gauges that read in ounces per square inch I worked with one years ago
    Just who did you get to calibrate your display on your truck was it expensive ??
  5. Feb 18, 2019 at 12:32 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    eurowner[OP] likes this.
  6. Feb 18, 2019 at 2:39 PM
    eurowner
    Scoty
    It boils down to my slow growing more present OCD, always present ADD, and the dash tells me 4 numbers that are not the same as my latest batch of gauges.
  7. Feb 18, 2019 at 2:40 PM
    eurowner
    Scoty
  8. Mar 7, 2019 at 12:00 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I use a Blue Point. Mine must be 20 years old.
    Remember - two different gauges may not (probably won't) read the exact same. You should always use the same gauge for adjusting your tire pressure - that way the settings are relative to each other.
  9. Apr 21, 2019 at 12:07 PM
    eurowner
    Scoty
  10. Mar 7, 2021 at 5:35 AM
    xLOGREx
    xLOGREx Well-Known Member
    Logan
    SL,UT
    2017 White SR5
    Little of this, little of that.
  11. Mar 7, 2021 at 2:32 PM
    eurowner
    Scoty
    Very happy with it.
    Hardscrabble likes this.
