Tire pressure gauges
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Callie2023!, May 20, 2024.
  1. May 20, 2024 at 5:56 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I have been using one of these for 35+ years and it’s always spot on.
    pdxTacoSR5, RIX TUX and Vlady like this.
  2. May 20, 2024 at 6:04 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Robnik, t0p_d0g and tvterry like this.
  3. May 20, 2024 at 6:24 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I compared 2 different pen style gauges against tpms readings (techstream) on 3 cars. Both were very close to tmps readings.
    t0p_d0g likes this.
  4. May 20, 2024 at 6:25 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    RustyGreen[QUOTED] likes this.
  5. May 20, 2024 at 6:26 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I bought these specifically because they were made in USA.
    I had one 30 years ago that I got from a racing outfit, they supplied racing 'stuff' and I did some
    computer programming for their business, cool people and the owner had a stack of 'em and told
    me to take one. Worked like a champ for years... but nothing is made like it used to be.... nothing.
    Robnik[QUOTED] and t0p_d0g like this.
  6. May 20, 2024 at 6:37 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Yes it is. :thumbsup:
    Not inexpensive, more a case of "buy once - cry once" .
    I've had mine for many years and it still checks dead on.
    I built this little tester for tire gauges -- yes, sometimes I over think things... :anonymous:
    dilbert and Robnik like this.
  7. May 20, 2024 at 7:01 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
  8. May 20, 2024 at 8:35 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    they are not connected, they use a signal and batteries and 7 years old......things dont last forever, time to spend some money
    using a tire gauge is good exercise
  9. May 21, 2024 at 11:45 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I had the same experience with this type of gauge. I am back to using my old pencil type gauges. They remain consistent and happen to match my TMPS closely. They are also smaller and handy to keep in the glovebox.
    I test them against a quality digital meter now and then and they prove their value.
    I use the TMPS readings to confirm that I do not have any leaks while driving.
  10. May 22, 2024 at 11:17 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I've had good luck with these cheap Chinese digital gauges:
    Slime Digital Tire Gauge (autozone.com)
    Use to use the pencil type (didn't we all) and found them to be getting too hard to read, i.e. eyes.
    Robnik likes this.
  11. May 22, 2024 at 11:30 PM
    Robnik
    Rob
    Greenacres, Florida
    I used to use the pencil type, as well. Found them very inaccurate. Try to get 2 consistent readings from them.
    I might try a digital, if nothing else to see if my analog is up to snuff, lol.
  12. May 22, 2024 at 11:41 PM
    Toycoma2021
    As you said earlier: "Key is to get an average reading & use that."
    Robnik[QUOTED] likes this.
  13. May 22, 2024 at 11:49 PM
    Sasquatchian
    Sasquatchian Well-Known Member
    I've been using Accu-Gage gauges for over forty years. They're affordable, consistent and quite accurate. Here's the statement from their website regarding their accuracy compliance:
    All of our dial tire gauges are ANSI Commercial Grade B gauges (meets ANSI B40.1 Grade B specifications). Unlike piston-plunger-type gauges, the bourdon tube movement is not affected by changes in temperature, humidity, altitude or air stream contaminants.
    The mechanical accuracy rating is ± 2% from 30% to 60% of scale and ± 3% below 30% and above 60%.
    For more information, or more specific accuracy specifications, contact our customer service department.
    I have three different versions right now so my target readings are in the relative middle of the range where they're more accurate - a 0-60 psi Schrader valve gauge for our vehicles, so with an accuracy rating of ±2% a reading of 35 psi could range plus or minus .7 psi. I have another 0-100 range Schrader valve gauge for setting the internal pressure on my mountain bike forks, which want to be around 70 psi and then a third Presta valve version for the mountain bike tires that ranges from 0-30 psi which is perfect for those 3" fat tires that want be 12 and 22 psi, depending on your riding conditions.
    Good gauges don't have to be expensive but you don't want to treat them well and not toss them around or drop them. I always get them with the ridged rubber bumper protective cover.
    RustyGreen, jego and Robnik like this.
  14. May 23, 2024 at 3:29 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Funny,…..mine doesn’t do that. It shows pressure as soon as I start driving
  15. May 23, 2024 at 6:17 AM
    #35
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    You quoted the wrong post. This thread is about tire pressure gauges.
  16. May 23, 2024 at 7:29 AM
    #36
    jego
    jego Well-Known Member
    2020 TRD Off Road DCSB
    FTW
    gr8-wrx likes this.
  17. May 23, 2024 at 7:42 AM
    #37
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Joe's Racing Products tire gauges. I have both high & low pressure units. Dead nuts and reasonably priced for regular folks.:thumbsup:
  18. May 23, 2024 at 10:27 AM
    #38
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    how the crap did that happen……?
  19. May 23, 2024 at 11:22 AM
    #39
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I found the engineer. There is no such thing as "over thinking"
  20. May 23, 2024 at 12:23 PM
    #40
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
