Tire Pressure Indicator Light
Discussion in 'Wheels & Tires' started by ryane3681, Oct 19, 2009.
  1. Oct 19, 2009 at 8:54 AM
    ryane3681
    ryane3681 [OP] Active Member
    Orlando, FL
    Toyota Tacoma Pre-Runner
    Hello -
    I recently purchased a 2008 Tacoma Pre-Runner and noticed that my tire pressure indicator light has gone on. I have checked the pressure in all tires, (except the spare because it is very hard to get to) and the light is still on. I even had a neighbor of mine whom is a mechanic and has seen this before, however he was unable to help.
    The truck only has 15,000 miles on it so I doubt it is something major. It is more annoying then anything else.
    Does anyone have any suggestions on is to what the heck could be causing this? It is very frustrating.....VERY!
  2. Oct 19, 2009 at 8:58 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    I believe there is a sensor in the spare too. You're gonna need to check it as well. And add air as needed. My indicator light has kicked on several times, and I've just added air to all five tires--This has fixed it each time. :)
  3. Oct 19, 2009 at 8:58 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
  4. Oct 19, 2009 at 9:00 AM
    carmellocafe
    KEVIN
    N. California
    BTW--Welcome to TW! :thumbsup:
  5. Oct 19, 2009 at 9:26 AM
    ryane3681
    Orlando, FL
    I will try that, I'm assuming that because the air valve on the spare tire is "bed side up" I will have to remove the entire tire, right?
  6. Oct 19, 2009 at 9:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW! :)
    You can lower it to the ground, or so. You dont have to remove it.
  7. Oct 19, 2009 at 10:39 AM
    ryane3681
    Orlando, FL
    I'm assuming that it gradually lowers from loosening it, right?
  8. Oct 19, 2009 at 10:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. Its addressed in the owners manual. :)
  9. Oct 19, 2009 at 10:52 AM
    Silver06Taco
    Silver06Taco Well-Known Member
    WA state
    Silver 06 DC TRD Sport
    Mine came on this weekend also. Drop the spare down and flip it over so the valve is pointing down, then put it back up. I've had to fill my spare twice in the past two months.
  10. Oct 19, 2009 at 10:57 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    If the spare is meant to be located with the valve "bed side up", has anyone put a flexible valve stem extension on to where you don't have to lower the spare every time you want to check it's pressure?
  11. Oct 19, 2009 at 11:03 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I have too too much fun keeping that damn light off on the wife's RAV4. Thank God they didn't put this crap on my base model prerunner, LOL.
  12. Oct 19, 2009 at 11:52 AM
    carmellocafe
    KEVIN
    N. California
    Strange--Mine's valve side down. I'm sure you can just take it out and flip it over. :confused:
  13. Oct 19, 2009 at 12:06 PM
    tacoeater
    tacoeater Well-Known Member
    Johnny
    Missouri
    07 TRD
    Weather Tech floor mats
    I had mine go off the other day also. Checked all my pressures and they were fine. Found a button under the steering wheel that said tpms so I pushed it. The light went off. So maybe the light comes on every 15k to remind you to rotate your tires. Kinda like the maintenece light coming on for oil changes.
  14. Oct 19, 2009 at 12:11 PM
    TightShirts
    TightShirts The StormTrooper
    TightShirts
    Phoenix... The Land of Lifted Trucks & Dirty Sluts
    08 Rugged Trail Ed
    Tint, Clear Bra, De-badged, In-Dash DVD, 09 Led Tail Lights, Chris4x4's old OME front shocks, 1.5" Deaver AAL with OME n182s, black billet in white sport grill, BHLM w/4500k HIDs + Fogs, bumper blackout
    it does not come on automatically, i just had that problem at 18.5k miles... i did find out however that you do have to push that button in order to get the light to go off once the tires are inflated and it can take a minute or two for the light to go off after pushing the button (i had a fun time at the dealership to figure that one out)
  15. Oct 19, 2009 at 12:14 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    If the light blinks for one minute straight, and then goes solid, one of your TPMS sensors is broken. If it just turns on then one of your tires' pressure is off.
    There is a TPMS reset button underneath the steering wheel. This is used to reset the system/initialize it. Dont hit this button unless you are planning to run a new tire pressure. What this button does is "teaches" the TPMS system that a new pressure is the standard. I think Toyota sets the standard like at 34psi. The TPMS light will come on when your pressure is off by 4psi (+,-). If your pressure is at 20psi, the light will come on. If, at this pressure, while the light is on, you reset the system, you are telling it that 20psi is the new standard, and thus the light will come on only when you go past 24psi or below 16psi.
  16. Oct 19, 2009 at 12:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I never had to push th button in mine....Just air up, and give it a min to figue it out...
  17. Oct 19, 2009 at 12:42 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Damn, so one of my sensors is busted then. Fuck stick.
  18. Oct 19, 2009 at 1:12 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    Yea you shouldnt have to push the button for it to turn off. When I hit the trails I air down and the light goes on but once I'm done, I air up again and the light turns off on its own, no buttons pushed.
  19. Oct 19, 2009 at 1:13 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    DId you recently get new tires?
  20. Oct 19, 2009 at 1:59 PM
    ryane3681
    Orlando, FL
    about the button under the steering wheel, I have noticed one there. when I purchased it, this past weekend, the dealer that I purchased it from had the pressure a good 4-7 psi more then what the owners manual said the psi should be. I have since aired down to the recommended psi setting.
    Should I now hit the button under the steering column to set it?
