Tire Pressure Indicator?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RickW, Aug 31, 2022.
  1. Aug 31, 2022 at 8:41 AM
    RickW
    RickW [OP] Well-Known Member
    Rick
    Stockton, Ca
    07 Tacoma daily driven
    The other day I got the TPI blinking.
    Got home and checked, all above 32lbs.
    Took a ride and the indicator was still blinking before it went solid.
    Any suggestions?
    TIA
  2. Aug 31, 2022 at 8:45 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Blinking TPMS indicator typically means one or more tire pressure sensors have failed.
    Wait what? likes this.
  3. Aug 31, 2022 at 8:56 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Probably failed. Take it to a shop who can check out which of one has failed.
  4. Aug 31, 2022 at 9:06 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Bad battery
    Get it scanned and see which battery died
    They are only good for 10
    Years max
  5. Aug 31, 2022 at 9:10 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    My 2011 is on borrowed time. Check your spare tire too.
  6. Aug 31, 2022 at 10:14 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Around 7-10 years is typical, although some last longer. I replaced the sensors in my 07 in 2021. They were still working, but I was getting new tire and there was no extra charge to install new sensors while mounting new tires. I bought mine from Amazon. They have been working perfectly for almost 2 years now.
    These will fit your truck. No sense in only replacing one, do them all.
    Amazon.com: MORESENSOR Signature Series 315MHz TPMS Tire Pressure Sensor 4-Pack | Preprogrammed for Select 200+ American Brand Models | Replacement for 9L3Z-1A189-A | Clamp-in | NX-S025-4 : Automotive
    And you'll need to buy a 5th one for the spare on that truck. I'm thinking 2008 was the last year they put them in the spare.
    Amazon.com: MORESENSOR Signature Series 315MHz TPMS Tire Pressure Sensor | Preprogrammed for Select 270+ Japanese Brand Models | Replacement for 42607-33011 | Clamp-in | NX-S008 : Automotive
    If your spare is over 10 years old I'd replace it too. Most tire stores won't work with you if the spare is too old. I picied up a decent used tire and paid $30 for the tire and to get it mounted.
    SWPA Tacoma likes this.
