Tire pressure is low
Discussion in 'Wheels & Tires' started by Tino4980, Nov 22, 2008.
  1. Nov 22, 2008 at 10:42 AM
    Tino4980
    Tino4980 [OP] Well-Known Member
    Bermuda Dunes, California
    09 TRD Off Road 4x4, 6 Speed , Magnetic Gray
    I bought my truck 1 month ago and i just noticed my tires are low, all four tires are 25 PSI and they suppose to be 35 PSI, just wondering if anynobody had the same issue i have ? Maybe because my truck is a 4x4 OFF ROAD and if you go off roading the tires have a better grip on the sand if the pressure is lower, ill just have to put air on the tires. Thanks Guys
  2. Nov 22, 2008 at 11:20 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Fill them up to what you feel is good we have plenty of discussions on what we think are the best ways to air up your tires. Either way make a note of what the psi is after you fill it up and check it every 2 or 3 days to see if it is holding. Not only that but has the temp. been changing where you live? That will also affect psi.
  3. Nov 22, 2008 at 12:33 PM
    Jeff
    Jeff Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    Check inside your door sill plate, your tire pressures will be there. Follow that as thats the bible, so to speak. You can adjust for off road, but for the street you should follow Toyota's spec's
    Jeff 06,V6, SR5, 4x4, V6
  4. Nov 22, 2008 at 12:39 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I've had my Taco since August of 2006 and had to inflate some of the tires here and there but not a lot of times. Maybe about 4 or 5 times tops and that was only for 1 tire at at time, never all 4 at the same time. The only time my light comes on is when its really cold outside and then it will go away once it warms up. Just keep checking it now and then and if it keeps happening I would get a hold of the place you bought it from cause that aint right.
  5. Nov 22, 2008 at 12:47 PM
    Jeff
    Hopkinton,MA
    I have had my Taco since Oct of 06 and only once did I have that light come and I had a nail in the tire and it was clearly down 12-15lbs and leaking fast. Other than that I never have had to put air in the tires , other than this first time with the spare.
    The cold weather does not seem to bother the light on my particular vehicle, perhaps one of the tires has a bad sensor. it does happen to all manufacturers.
    Jeff , 06,V6, SR5 4x4, 6spd
  6. Nov 22, 2008 at 1:40 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah Jeff I'm not to worried about the light coming on when its cold outside because it only happens once every blue moon even when it does happen. Plus I'm adding new rims and tires next week so they will be messing with the TPMS system anyways. Thanks though.
  7. Nov 22, 2008 at 2:15 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    What "issue" do you have? That they're low on air? So put some in.
    :der:
  8. Nov 23, 2008 at 11:57 AM
    Tino4980
    Well the weather here hasnt changed much just getting a little cooler, the light for my tire pressure hasnt turn on yet but im still going to put air on them and then ill try your advice and check 2 or 3 days and see what happens , dont know why they sold me my taco with the tires pressure not with the right PSI of 35, Thanks guys for your input
  9. Nov 23, 2008 at 12:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The "right" psi depends on the tires. My AT's are set at 32# front 30# rear on my Tacoma. You should do a "chalk meathod" on your tires to insure propper inflation.
  10. Nov 23, 2008 at 12:53 PM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
    Make sure your gauge isn't pouched.
    Seems to happen to us all the time at work. Someone will drop the gauge and not tell anyone then you go to use it and it will be out by like 10 or 15 pounds on a 90psi truck tire.
  11. Nov 23, 2008 at 2:37 PM
    Jeff
    Hopkinton,MA
    Tino, not sure why your dealer did not check your tire pressures when you bought it. With regards for your 09 tire pressures, most of us that have 06 all the tire pressures are at 29 according to your sticker on your door post, that sticker has your tire size that came with your truck and the correct tire pressure. What does yours say? If for some strange reason that your tire size on your truck does not match the sticker on your door post, then there is some thing wrong and you dealer should give you a good explanation. Let us know . You also might look at the window sticker that came with your truck listing the VIN, options, tires, color etc. All that info should jive too.
    Jeff 06, V6, SR5, 4x4
  12. Nov 23, 2008 at 2:45 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^He has a TRD OR which has 265/70/16 tires that are the same as previous years, 29psi front and 32 rear. This is exactly my point: the guy has an "issue" with his tires being down by 4 and 7 PSI. It's a NON-issue. The TPMS doesn't even go off that low.
    Someone in Cali invite him over for a tire inflation meet.
  13. Nov 23, 2008 at 3:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    lmao!!!!
  14. Nov 23, 2008 at 3:20 PM
    aaronatl
    aaronatl ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
  15. Nov 25, 2008 at 3:05 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I don't know where you get 35lbs. My door sticker says 29 for all 4 (265/75/16 dunlops on a 4x4 was how it came), but I have different tires now and I'm going to try the chalk method when I can remember to get some chalk :D .
    The TPMS must warn the driver when a tire is under-inflated by as much as 25% and TPMS should be set at the lowest cold inflation pressure recommended by the manufacturer. So 29lbs would go on at 22lbs, you have 25lbs which is why it is not on yet. 4lbs loss could be due to it being colder out, that's what 1st activated mine.
    There was a post reference the reset button and being able to put a certain pressure in all the tires, push the reset and it recognizes the 'new' pressure as the default and will activate when it gets 25% lower than the new #. I haven't looked for the button or tried this yet though.
    try this...search...put air in...check owners manual/door panel :rolleyes:
  16. Nov 25, 2008 at 5:54 AM
    Jeff
    Hopkinton,MA
    Well said FoxySandChick, you go by the door sticker pressure recommendations which should match the tires that originally came with the truck. Then go from there.
    Jeff, 06,V6,SR5, 6spd 4x4
  17. Nov 25, 2008 at 4:48 PM
    Tino4980
    Yes it does say 29 front and 32 rear on my sticker cool, i put air on them already so ill just wait and see if theres no problems ill let you guys know. So far im loving my truck you guys and TW are awsome. Again thanks guys
  18. Nov 25, 2008 at 8:35 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hey I'm sure you know, but after you fill the tires up with the right pressure you need to hit the reset button under the steering wheel and hold it until the low pressure light blinks 3 times. After that it should go out if the pressures right.
