Tire Pressure Light Flashing (Replaced TPMS Sensors)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HKG, Aug 4, 2025.
  1. Aug 4, 2025 at 7:39 PM
    HKG
    HKG [OP] Member
    Hudson
    Unincorporated King County, WA, USA
    '14 TRD Offroad Access Cab (6MT)
    Modifications: - Unifilter Mod - Seat Jackers (Driver & Passenger) - Maglite attached to drivers side seat jackers - DIY Maglite mounting bracket attached to seatjackers - Midland GMRS Radio with Comet CA2x4SR Antenna - Hardwired Dashcam - Truxedo Truxport Tonneau Cover - Lockable Tailgate Handle (Installed by Previous Owner) - OEM Folding Bed Step - OEM Running Boards (to prevent door dings) Additional Vehicle Info: - 4.0L V6 - 6-Speed Manual Transmission - Blue Ribbon Metallic - Towing Package
    Hi,
    I have had an issue with the TPMS light on the dash flashing for a bit then going solid (its been doing this for almost a year). Research said that it was the TPMS sensors not working.
    Well I just had my tires replaced at Discount Tire and I also had them replace the TPMS sensors. But as I was driving back home, the light stared flashing again.
    Got any ideas on what the issue could be?
    HondaGM likes this.
  2. Aug 4, 2025 at 7:42 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Did they program the sensors..
    Dm93 likes this.
  3. Aug 4, 2025 at 10:02 PM
    HKG
    HKG [OP] Member
    Hudson
    I assumed they did. I know they reset the TPMS thing on the dash itself.
    HondaGM[QUOTED] likes this.
  4. Aug 5, 2025 at 7:35 AM
    MR5X5
    MR5X5 Well-Known Member
    Have you checked air pressure in the spare? Was it also replaced?
    HondaGM likes this.
  5. Aug 5, 2025 at 7:39 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Flashing and then going solid means one or more of the sensors are not programmed into the TPMS ecu.
    Naveronski and HondaGM like this.
  6. Aug 5, 2025 at 7:45 AM
    545 Well-Known Member
    2015 Access Cab
    I don’t believe second gens allow more than 4 tpms sensors at a time
    HondaGM likes this.
  7. Aug 5, 2025 at 7:51 AM
    MR5X5
    I believe the spare is read too....
  8. Aug 5, 2025 at 8:13 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The last year the spare had a sensor was either 2008 or 09. My 07 has 5 sensors and I have to check the spare occasionally. The OP's 2014 won't have one in the spare.
    Take it back to Discount Tire. One of the new sensors is not programed.
    HKG[OP] and nettereo16 like this.
  9. Aug 5, 2025 at 8:14 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    05-08 had 5 sensors, somewhere around 09 they went to 4.
    Sounds like either they didn't program the sensors correctly or one or more is bad/incorrect.
    HKG[OP], HondaGM and MR5X5[QUOTED] like this.
  10. Aug 5, 2025 at 1:47 PM
    HKG
    HKG [OP] Member
    Hudson
    I took it back and it appears that one of them was bad. Glad it's not spare tire related.
    Dm93[QUOTED] likes this.
