tire pressure light is on after new tires??
Discussion in 'Wheels & Tires' started by toyotadude5, Dec 6, 2009.
  1. Dec 6, 2009 at 3:03 PM
    toyotadude5
    toyotadude5 [OP] Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    i lifted my truck and got new bigger tires put on. Is it normal for the tpms light to be on all the time now??
  2. Dec 6, 2009 at 3:04 PM
    98tacoma27
    Ben
    Not Beech Creek
    No, unless the sensors were removed
  3. Dec 6, 2009 at 3:05 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Are your sensors still in the tire?
  4. Dec 6, 2009 at 3:09 PM
    toyotadude5
    chris
    Flagstaff, az
    sorry im not sure where to look. They are the same stock rims. Where are they located? behind the tire? or on the rim somewhere?
  5. Dec 6, 2009 at 3:11 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    They are on the rim- If your valve stem is metal then they are still there. If they are not- I'd be REALLY pissed.
    Do you know what they pumped the new tires up to and have you tried the reset button yet??
  6. Dec 6, 2009 at 3:16 PM
    toyotadude5
    chris
    Flagstaff, az
    i just checked the rims, and they still have the metal stems coming out of rims. Im not sure what tire pressure they pumped it up to. And where is the reset button?
  7. Dec 6, 2009 at 3:21 PM
    senor taco
    Monterey Bay, Ca
    By the gas pedal area. Also check the tire pressure in the spare.
  8. Dec 6, 2009 at 3:22 PM
    rick
    rick `
  9. Dec 6, 2009 at 3:22 PM
    08ruggedtrail
    08ruggedtrail Well-Known Member
    shannon
    south carolina
    1991 v6 4x4
    lifted
    under your dash on the drivers side. its a small button
  10. Dec 6, 2009 at 3:28 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    If the light blinks for a minute then goes solid then they broke one of your sensors. If it just stays on solid from startup, air pressure is off. DON'T RESET the air pressure!!! Adjust it you your desired psi and if it's still on, reset it.
  11. Dec 6, 2009 at 3:30 PM
    toyotadude5
    chris
    Flagstaff, az
    ok pretty sure it doesnt blink. It just stays on from startup
  12. Dec 6, 2009 at 3:39 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    If it doesn't blink, figure out what proper pressure for your tires is and set it at that. If it still stays on, reset the sensors
    via the reset button under the steering column
  13. Dec 6, 2009 at 3:46 PM
    newfie8
    newfie8 Well-Known Member
    newfoundland
    09 tacoma
    Tinted windows all around. Fog lights. Intermittent wiper switch. Skid plate. Extra D rings. Grillcraft. Color matched grill. Hella 500ff HID behind grillcraft. Rcbs204 Lighting. 5100's up front. 265/75/16 Duratracs.Firestone riderites. Bora Wheel spacers. Tinted tails. De badged. Blacked out rims.
    Worst case scenario the guy who changed over your tires damaged the sensors in the process! Happened to a friend of mine and the garage had to buy him a new one.
  14. Dec 6, 2009 at 3:49 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    They broke mine too when I got my mojaves and km2s put on. They broke 3/5 sensors. They replaced them all too but it was a pita. If it doesn't blink tho, all sensors are functioning properly and it's just a matter of adjusting pressure
  15. Dec 6, 2009 at 5:54 PM
    Tdup
    Tdup Well-Known Member
    Trey
    Columbia, SC
    2021 TRD Off-Road 4x4 DCSB 6MT
    Redarc brake controller, CamLocker tool box, OEM Bed lights.
    this same thing happened to mine, your spare pressure has to be within like 7psi of all your other tires (ex. i run cooper discoverer stt @ 40psi, my spare was @32, so it threw the tpm) just run your spare up to about what you have in all 4 tires and you should be fine
  16. Dec 28, 2009 at 9:51 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    My TPMS light is on, and it blinks for a lil bit and then it goes solid. So im guessing there broke? I still have the stock rims and tires, but one of my tires have a leak and got really low once. So if I hit a big bump with it like that im sure it could have damaged one?
  17. Dec 29, 2009 at 6:04 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...If it's blinking you have a broken sensor-A bump could have done it.
  18. Dec 29, 2009 at 7:38 AM
    Tdup
    Trey
    Columbia, SC
    doubt if its broken because mine blinked and as soon as i got all tires to about the same psi it went away, check tire pressure in your tires. if there stock you should run them all (including spare) @ 32psi once you have that reset the light and see what happens, if it still blinks broken sensor, if it goes off your good to go.
  19. Dec 29, 2009 at 8:26 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Blinking = Broken/non comunicative sensor- That's the way the system works. If you reset the system and it really was blinking you may have gotten the sensor to read again...or maybe you just thought it was blinking??
  20. Dec 29, 2009 at 4:52 PM
    Tdup
    Trey
    Columbia, SC
    blinking=broken, and your right there but blinking and going solid means pressure in one or more of the tires is not right, and if that is corrected the light will go off, and checking this and resetting the light is completly free so it wouldn't hurt Josh to check everyting before replacing something that may not be broken.
