Tire pressure light
Discussion in 'Wheels & Tires' started by Jeff, Nov 19, 2008.
  1. Nov 19, 2008 at 2:18 PM
    Jeff
    Jeff [OP] Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    My tire pressure light just came on, thought I might have a tire starting to go down, like last time.
    However after checking the pressures. everything is at 29lbs . Does anyone know where that sensor is and is there any way of resetting it? Thanks.
    Jeff, 06,V6, 6spd, 4x4 bone stock.
  2. Nov 19, 2008 at 2:19 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    Did you check your spare?
  3. Nov 19, 2008 at 2:20 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    ^^^yep, thats probably what it is.
  4. Nov 19, 2008 at 2:23 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    BTW...the sensors are part of your valve stem in each of the 5 tires...
  5. Nov 19, 2008 at 2:25 PM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    'cept for the 09's that have only 4 no sensor in the spare.
    Jeff, when you check it, flip it over, makes checking it next time a breeze!
  6. Nov 19, 2008 at 2:26 PM
    c80drew
    c80drew Member
    Same thing happened to me today... fired the truck up to go to work, tire pressure light is on. Checked tires, all at 30psi - is it possible that the light comes on when the temperature gets too low and they are over 29?
  7. Nov 19, 2008 at 2:28 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    yes that happened to me checked all tires and the spare i just needed to drive warm them tires then went off.
  8. Nov 19, 2008 at 2:29 PM
    Jester243
    Dan
    Spokane, WA
    Not if they are filled with nitrogen gas :poking:
  9. Nov 19, 2008 at 2:53 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Definately the spare. It happened to me last winter about 2 miles down the highway. I pulled over asap expecting to find a tire losing air. It was only later in the day I remembered the spare which was down to 26PSI when I checked it that night.
  10. Nov 19, 2008 at 4:19 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
  11. Nov 19, 2008 at 7:27 PM
    redrazr
    redrazr Psalm 118:5-6
    Baker, FL
    2001 Xtracab TRD PreRunner
    Bilstein 5100 front/rear, Method NV Diamond wheels, Mickey Thompson Deegan 38 265/75-16's
    yes every time it gets cold here my sensor light comes on.
