Tire pressure light
Discussion in 'Wheels & Tires' started by snowgod06, Dec 8, 2009.
  1. Dec 8, 2009 at 11:24 PM
    snowgod06
    snowgod06 [OP] UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    so its been below freezing here in oregon the last few days. And my tire pressure light came on. I understand that cold weather makes the pressure drop in the tires. Well my light came on and i checked them all including the spare and there all right where they normally are. Soooo.. im stuck on what may be causing the light to stay on. I read the manual and my light isn't doing what the manual states..It stays on, without flashing at all. So any help on this i would gladly appreciate it.
  2. Dec 8, 2009 at 11:41 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Hmmmm...maybe there off by just the slightest bit and thats whats triggering the TPMS Light...not sure bud
  3. Dec 8, 2009 at 11:59 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I think if you hold the TPMS button under your steering wheel, it will reset them and 'assume normal tire pressure' as what you have at the moment. I know thats what the Les Schwab guys did for me with my 33's since they run at a different pressure. You might want to call them, I'm sure they could tell you exactly how it's done, I'm not positive.
  4. Dec 9, 2009 at 12:23 AM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    I was going to say check the spare but I read that you did it already.... oops
  5. Dec 9, 2009 at 12:25 AM
    Jedidiah
    Jedidiah TakeItEasy
    Oregon
    BHLM Bilstein 5100's BFG AT 285's HID (6000K) Maglite Grillcraft Grill debadged
    Mine is doing the same thing! Im not to sure what to do so i've been ignoring it for the past 2 days!
  6. Dec 9, 2009 at 12:33 AM
    snowgod06
    Rob
    06 Access Cab
    is there some special process on pushing the reset button. Ive tired holding it down for forever and everything i could think of, but it seems to not be working.
  7. Dec 9, 2009 at 12:58 AM
    tacomarich
    tacomarich luvsoffroading
    rich
    arizona
    trd 4x4 offroad
    my light came on last week with the drop in temp here. i'm sure my tire pressure is fine though. i'm going to reset the freaking light tomorrow. what you do is, turn your key to the on position, then press and hold the reset button under your steering wheel and hold it until the light flashes three times. hope that helps. its supposed to shut off. do this assuming all your tires are at the correct psi levels.
  8. Dec 9, 2009 at 2:13 AM
    brian
    Elizabeth City, NC
    that was gonna be my next suggestion, same general process as the 'maint req'd' light. I just wasn't sure the first time around.
  9. Dec 9, 2009 at 2:47 AM
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    well the manual says to reset it after a tire rotation, after tire or wheel replacement; when the inflation pressure is changed. or when replacing the ecu or when replacing the air pressure sensors. however, i want to know if resetting it can cause other issues, if none of the above?
    looks like it will if you don't first adjust the correct psi on all four tires, including your spare. it says the light might come on when your psi levels are normal. or it wont come on at all, if your psi levels are low, if you dont adjust the correct psi levels. :confused: feaking light causes more issues than i want to see in a light. it looks like someones ass is mooning you... lol
  10. Dec 9, 2009 at 4:16 AM
    FirstCohort
    FirstCohort Well-Known Member
    Northern Virginia
    10 SR5 DC LB 4x4 BSP
    WeatherTech Vent visors, access soft roll-up bed cover, factory side steps, factory bed mat, weathertech floorliner fore and aft, tinted front windows- State legal 50% : (
    I'm having the same issue with the cold temps. In the morning the light stays on for my entire drive in to work. As the temps rise slightly during the day the light goes off on the drive home. It can't be pressure because I have checked all tires in the freezing cold. What a big PITA it is to check the pressure on the spare in freezing cold weather! I'm going to have to back the ass end into the garage and drop that down and flip it soon. Just have to heat up the garage a little first. BRRRRR
  11. Dec 9, 2009 at 8:01 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    yes one of toyota's murphy law is to have the spare trigger during the wintery-est weather. Mine is flipped now.
  12. Dec 9, 2009 at 11:07 AM
    bledsoe3
    bledsoe3 Well-Known Member
    Portland
    '15 DCLB Limited
    SnugTop, Air Lift bags, Bilstein 5100's up front, AAL in rear, 275/70/18 BFG AT TA KO2, URD TCAI, URD Cat Back
    I'm in Oregon too and having the same problem. I set the tires to the same pressure and held the reset button until it flashed. The light came right back on. It must be the cold snap we're have out here.
  13. Dec 9, 2009 at 11:10 AM
    snowgod06
    Rob
    06 Access Cab
    yea, i reset it. It turned off till i drove around and turned off my truck. Started it about 5 min later to head home, and yup came back on. I give.. haha i'm going to just going to deal with it till the cold snap goes away then try again.
  14. Dec 9, 2009 at 11:17 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    All 5 tires have to be close in tire pressure. I had this problem last year, because I had increased the pressure in the road tires, but not the spare. When it got cold the spare tire turned on the light. I just added some air to the spare and the light went out after a few minutes. I've rotated my tires twice and have changed air pressures slightly and have never used the reset button. This week in Reno it is very cold and my light has not come on. At least not yet.
    Edit. I just re-read your post and I noticed you checked the spare. If after it warms back up and your light doesn't go out, you may have a bad sensor in one of the tires. Just a thought.
  15. Dec 9, 2009 at 11:21 AM
    bledsoe3
    Portland
    '15 DCLB Limited
    I guess I'll check the spare. I need to anyway since I'll be driving to Vegas in a couple of weeks. At least it won't be this cold there (we're up to 24*).
  16. Dec 9, 2009 at 11:22 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Don't ya just love the TPMS crap? I've seen this happen with my truck when the temperature gets cold. I think what happens is when you drive around the tires heat up and cause the pressure to be higher than the spare which stays cold under the truck.
  17. Dec 9, 2009 at 11:25 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Yea, I hate tpms. I think in 2009 Toyota took the sensor out of the spare to avoid this problem. I guess too many people are too lazy to use an air pressure guage so the Govt. had to pass a law that all light duty vehicles have tpms.
  18. Dec 9, 2009 at 12:04 PM
    OffroadToy
    I wonder if Toyota would be willing and able to reprogram my 07 to only have 4 sensors...get rid of the one in the spare. Anyone tried this?
  19. Dec 9, 2009 at 12:17 PM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    Where is the transmitter at? I always thought it to be in the valve stem and that if you took it out and installed a standard valve stem then it just would not transmit anymore. But I guess if the receiver is programmed to receive five values then that would not work.
    When you get new wheels do they use your existing valve stems or do you have to buy new TPMS? Surely the transmitter is not part wheel itself?
  20. Dec 9, 2009 at 12:18 PM
    Jedidiah
    Jedidiah TakeItEasy
    Oregon
    Its gotta be the cold weather if we're not the only ones in oregon with this problem!
