Tire pressure light
Discussion in 'Wheels & Tires' started by snowgod06, Dec 8, 2009.
  1. Dec 9, 2009 at 12:22 PM
    98tacoma27
    Ben
    Not Beech Creek
    Transmitter is under the valvebody. You can't see it out side of the rim. It is all one unit.
  2. Dec 9, 2009 at 12:24 PM
    BravoZulu469
    BravoZulu469 Well-Known Member
    NorCal
    06 Superwhite TRD O/F
    Pioneer Deck, CB Radio, 3 inch body lift, exhaust soon,
    I live in Spokane, WA and I've been having the same problem :/ I'm pretty sure it's the cold weather cause one day it was 35ish outside then the next day and from then on, it was 25 and below and that day the light went on and has been on since. I got my tires siped at LesSchwab and they checked the pressure and said all was fine. They also said that the light comes on when the tire is 25% under inflated.
  3. Dec 9, 2009 at 12:24 PM
    98tacoma27
    Ben
    Not Beech Creek
    Looks something like this.
  4. Dec 9, 2009 at 12:54 PM
    tanktodd
    tanktodd Well-Known Member
    Todd
    back on the right side of the bay, Ala
    08 Prerunner w/TRD Sport Pkg
    Limo tint in back w/ 20% on doors. Removed all badges. Stereo headunit, all new door speakers, 2 amps, and 10' sub...so far Black bullbar MotoMetals and 285/70/17 Duratracs. 3" OME springs in front and aal in back with tsb springs Black UWS tool box 5100's all around Plasti-dipped evo front end Fog light anytime mod OEM steps (for sale) HID fogs 55w 3000k HID heads 35 w 6000k "Cool white" dome & map lights
    It's probably the spare. I live in Alabama and in September I went to Canada for vacation. My light came on and I checked the tires and nothing, took it to dealer up there and they found out it was the spare. Cold weather must have gotten to it...they told me if it was off by 4-6 pounds i think they said the tpms would go off.
  5. Dec 9, 2009 at 1:01 PM
    THE TECHNICIAN
    THE TECHNICIAN Well-Known Member
    Set the spare to 38 and the rest to 36. Make sure you have an accurate gauge. If the light stays on it's time to take it in.
  6. Dec 9, 2009 at 1:02 PM
    jerris
    jerris Well-Known Member
    jerris
    utah
    07 double cab, 6 inch fabtech 35 duratrac
    6 inch lift, 35 inch duratrac's
    hey i worked at discount tire and they have a tool to reset them also the light will come on if you have the littlest difference between the tires. and some sensors read low when you scan them it will tell you what your sensor is reading. anytime we had a temp drop we would have people coming in all day long with the light tpms light on.
  7. Dec 9, 2009 at 1:40 PM
    jammdogg
    jammdogg Well-Known Member
    James
    Hillsboro, OR
    13 Spruce Mica DCLB
    6" ProComp lift on 35 MT's. ARB Bumper.
    Same issue here. Was at the stealership anyway, so they reset it. Has not been an issue since.
    Pretty friggin cold in the OR!
    James
  8. Dec 9, 2009 at 2:01 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    We haven't been this cold in Reno since 1988. The west coast has briefly become the mid west. All though, they are getting hit pretty hard right now too.
  9. Dec 9, 2009 at 2:13 PM
    BravoZulu469
    NorCal
    I'll be driving through Portland in a week, any expectation of snow?
  10. Dec 9, 2009 at 2:14 PM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    Do what I did, fill them up to 40-42 psi you won't have the light come on for years!
  11. Dec 9, 2009 at 3:57 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    try nitrogen,pressures dont vary,rides better
  12. Dec 9, 2009 at 6:49 PM
    snowgod06
    snowgod06 [OP] UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    doubt it, freezing rain maybe friday night. After that just same ol oregon weather. mid 40-50s and rain.
  13. Dec 9, 2009 at 7:20 PM
    t-frax
    t-frax Well-Known Member
    Cali
    08 PreRUNNER TRD Sports Pkg, Black
    Pop&Lock, Bakflip, spare tire lock, folding hitch step, alarm, n-fab steps, more to come hopefully
    I am pretty sure it is just the cold weather messing with the sensors. I live in cali and just in the past couple days it has dropped to 35degrees after raining which is when my pressure light came on. I checked all my tires and spare and all was the right pressure. i started to freak. but i read some other threads that cold messes with the sensors...not that the cold messes with the pressure but the sensors themselves. the light was on all day yesterday. but today it warmed up a bit and just as i was coming back from lunch, the light just turned off. so if all your tires are the right pressure, it is probablly just the cold messing with the sensors. it should go away once it heats up. cant say when that will be but thats what i dealt with.
  14. Dec 9, 2009 at 10:35 PM
    JKD
    JKD Well-Known Member
    Nitrogen still obeys Charles' law.
  15. Dec 10, 2009 at 4:42 AM
    #35
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    As in Las Vegas NV?? It's 26* here right now, so don't leave the jacket at home :laugh:.
    We are in the 30's at night and 50's during the day right now.
  16. Dec 10, 2009 at 11:58 AM
    #36
    snowgod06
    Rob
    06 Access Cab
    30's and night and 50's in the day. I wish we had that, were lucky to get to 30 for a HIGH
  17. Dec 10, 2009 at 12:06 PM
    #37
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    Looks like you gotta go in for the TPMS tsb!!! No really if your tire pressure is where YOU want it then just ignore the idiot light.
  18. Dec 11, 2009 at 7:32 AM
    #38
    bledsoe3
    bledsoe3 Well-Known Member
    Portland
    '15 DCLB Limited
    SnugTop, Air Lift bags, Bilstein 5100's up front, AAL in rear, 275/70/18 BFG AT TA KO2, URD TCAI, URD Cat Back
    I checked the spare and it was low. After I filled it the light went out. Too bad Toyota put the stem up so I had to drop the spare to get to it. When I put the spare back in, I flipped it so the stem is down.
  19. Dec 11, 2009 at 7:57 AM
    #39
    bledsoe3
    Portland
    '15 DCLB Limited
    Yes, I bought a condo in Desert Shores and I'm coming down on the 26th to do some remodeling. It's 9* here right now. 50* will feel like a heat wave.
  20. Dec 11, 2009 at 8:31 AM
    #40
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
