Tire pressure moderating system scam?
Discussion in 'Wheels & Tires' started by toyotatruck11, Jul 2, 2014.
  1. Jul 2, 2014 at 9:15 AM
    toyotatruck11
    toyotatruck11 [OP] Well-Known Member
    Alberta canada
    Tacoms SR5, tow package undergoing transform
    If I haveVSS (Vehicle speed sensors) that turn on my dash light if my tire gets low onair pressure why do I need to spend a bunch of extra $$$ on these??? Plus Iwould guess to balance them you need some big weights..
    · ADD Tire Pressure Monitor System
    · By: Suspension Kits
    · Part Number: ADDTPMS
    · Price:CDN$ 159.99 EA
    · Qty:
    · Overview
    Set of 4. UniversalT.P.M.S. or Tire Pressure Monitor System. You will be contacted by a salesperson to check for proper fitment to your vehicle. May not fit all vehicles.Set of 5 will be an additional fee based on application
  2. Jul 2, 2014 at 2:24 PM
    toyotatruck11
    Alberta canada
    This better?
    If I have VSS(Vehicle speed sensors) that turn on my dash light if my tire gets low on airpressure why do I need to spend a bunch of extra $$$ on these??? Plus I wouldguess to balance them you need some big weights..
    · ADD Tire PressureMonitor System
  3. Jul 2, 2014 at 2:26 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    wut
  4. Jul 2, 2014 at 3:08 PM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    What are you trying to say???? You don't need to buy additional TPMS units, your truck already has them, you can switch them out from your oem wheels if you get new wheels. They usually need replacement every 4-5 years
  5. Jul 2, 2014 at 9:05 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Damn Canadians.:confused:
  6. Jul 6, 2014 at 9:39 PM
    toyotatruck11
    Alberta canada
    LOL, naw the guy at fountain tire is trying to tell me its $110 each tire to change them over to a new rim. I couldn't believe it. All you have to do is just remove them and put them into the new rim/tire combo correct?
  7. Jul 6, 2014 at 9:48 PM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    Depends on the wheels. What wheels were they on and which ones are you getting?
    I think the ones off the steel wheels are different correct?
  8. Jul 6, 2014 at 9:56 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The valve core part of the sensor and a few seals and O-rings need to be replaced when the sensor is transplanted. The tire shop should be charging you a "rebuild kit" or "service kit" instead of replacement sensors.
    And sensors between steel and alloy wheels are not interchangeable due to different mounting angles.
  9. Jul 6, 2014 at 10:48 PM
    RND2
    RND2 Well-Known Member
    In my head swimming around
    12 DCSB
    RCD 4"
    They have always removed mine from factory rim and installed on new rim but they tell you they must rebuild them and Ive called bullshit they're new and never got charged on two sets of rims on two different vehicles
