Tire Pressure Monitor Sensor fault code
Discussion in 'Wheels & Tires' started by Happytrades, Jun 25, 2022.
  1. Jun 25, 2022 at 10:21 AM
    Happytrades
    Happytrades [OP] New Member
    Tom
    2006 Tacoma SR5
    I just had the wheels on my truck repainted. When I picked it up, the TPMS on the dash was on. I tried resetting it with the button under the steering wheel, but that didn't work. Next I took it to the tire shop, and they replaced a sensor in one of the wheels. But they were able to get the dash sensor to go off. They then told me that they were getting a fault reading saying that maybe it was the receiving unit in the car that was bad. I am a little skeptical because this has happened before and I was told by the same tire shop that the device they use had to be configured to get the light to go off. I called the local Toyota dealership and was told their rates are $185 per hour and that if the unit is bad, it would cost $800 to buy a new unit.
    I know that I could use a piece of electrician's tape and cover the light, but I would rather that the darn thing work as designed.
    Any ideas?
  2. Jun 25, 2022 at 10:25 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I think you might have a sensor in your spare based on the year. If it's the original sensor, it's likely dead by now. I'd make sure you have 5 good sensors before blaming the receiving unit.
  3. Jun 25, 2022 at 12:51 PM
    Happytrades
    Tom
    2006 Tacoma SR5
    Thanks but they checked that.
  4. Jun 28, 2022 at 3:34 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    There could be several causes of this, we can help further if you are near one of our store locations. PM on the way.
