Tire Pressure Monitor Wont Go Off.
Discussion in 'Wheels & Tires' started by Tikibeast, Feb 15, 2009.
  1. Feb 15, 2009 at 1:19 PM
    Tikibeast
    Tikibeast [OP] The Savage
    Victorville, Ca
    2006 Prerunner SR5, Reg Cab totally stock.
    Nada...need some guidance there it's going to see a lot of highway mileage not just trail miles.
    So I increased the pressure in my tires to 44psi for mileage and handling reasons (lots of highway miles and when I got the truck I had three tires at 40 and one at 35 so I figured I may as well). I reset the monitor (little button under the steering wheel) and it started flashing and then came back on:confused:
  2. Feb 15, 2009 at 1:21 PM
    6shooter
    6shooter Well-Known Member
    portland, or
    06 sport........
    plenty.......
    44? jesus, bet that rides like shit.
  3. Feb 15, 2009 at 1:25 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    Check your spare for the same pressure you are running in the others
  4. Feb 15, 2009 at 1:34 PM
    Tikibeast
    Victorville, Ca
    Seriously? I didn't think my spare had a sensor in it...I'll do that when I get back from snow duty on Tuesday.
  5. Feb 15, 2009 at 1:40 PM
    jolayiv
    Jim
    Hertford NC
    Yep. It has been the prob for countless other TW members.
  6. Feb 15, 2009 at 1:44 PM
    6shooter
    portland, or
    06 sport........
    plenty.......
    yeah, it's the spare. also, you have an 06 so it is possible to disable it if you wanted to.
  7. Feb 15, 2009 at 2:06 PM
    MacTaco
    MacTaco Mustache May
    Pensacola, Florida
    06 Indigo, Lifted, Flowmaster
    Skyjacker 3" Lift, 285/75/R16 Toyo M/T tires/ Eagle Alloy Wheels, Flowmaster 50 Series, Pioneer Din Head Unit, Viper Alarm/Remote Start System, Debadged, DT Headers, True Flow Intake
    What would I have to do to disable it. Besides get it reprogrammed at the stealership.
  8. Feb 15, 2009 at 4:11 PM
    cmfranks
    cmfranks Well-Known Member
    Craig
    Austin,TX
    08 DC Pre-Runner 6in Pro Comp Lift
    BHLM, Pro Comp Skid Plate, AFE Drop in Air Filter, Tint, Pioneer AVH 4000 DVD,Polk Audio 6.5 components, Polk 6.5 co-ax's, Polk Audio 400.1 amp, Polk Audio 500.1 amp, (2) Polk Audio 10 in Momo subs, Mr Marv sub box, Sockmonkey decals, Redline Elite hood struts, Bak Flip tonneau cover, N-Fab Nerf bars, Painted Center Console & Window/Door Lock Panels Black, Amber LED Dome/Map Lights
    i believe you can hold the reset button for 15 seconds while you are driving. from my readings, if you ever want it to work again it would cost around $70 at the dealership to fix it.
  9. Feb 15, 2009 at 4:14 PM
    stephbm6
    stephbm6 Well-Known Member
    West Jordan, Utah
    2019 TRD OR Double Cab
    Wouldn't it wear the inside tire tread a lot faster?
  10. Feb 15, 2009 at 4:25 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I hooked up one of those air hose extensions on the spare so I could check it and refill it without crawling under the truck. Problem is, when attached the hose causes the panel light to indicate a tire pressure problem. But I really don't want to disable the TPM.
  11. Feb 15, 2009 at 4:38 PM
    AK27
    AK27 Well-Known Member
    do the tpms also report too high of a pressure? the mechanic that put my winter tires on warned me that the light might be on since he jacked up the pressure after install
  12. Feb 15, 2009 at 6:55 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    I've had my hose extension hooked up now for about 4 weeks and it hasn't triggered my light to come on at all. Did you put the cap on yours? I did and zip tied mine to the hitch.
  13. Feb 15, 2009 at 7:17 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    yes. I'll try it again tomorrow.....
  14. Feb 17, 2009 at 1:43 PM
    Tikibeast
    Victorville, Ca
    It road a little rough at 35psi so I don't really notice a difference. We'll see how it rides when I get my new Silent Armors.
  15. Feb 17, 2009 at 1:55 PM
    Tikibeast
    Victorville, Ca
    Ok so pressurize my spare to the same pressure as my other tires, reset again and I should be good?
  16. Feb 17, 2009 at 1:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    yep.
  17. Feb 17, 2009 at 2:06 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I put 32 lbs in all my tires including the spare, attached an air hose extension to the spare and reset the TPM (tire warning light flashed a few times and then went off). Everything working fine, life is good.
  18. Feb 17, 2009 at 2:18 PM
    Tikibeast
    Victorville, Ca
    Good to know ty.
    Well I intend to keep them around 44 since like I said I do a lot of highway driving and I want to get the most mileage I possibly can but I'll look into that extension hose idea ty.
  19. Feb 17, 2009 at 2:37 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
  20. Feb 17, 2009 at 2:43 PM
    Tikibeast
    Victorville, Ca
    Nice, what was the cost on that one?
