TIRE PRESSURE MONITORING SENSORS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lodawg, Apr 21, 2012.
  1. Apr 21, 2012 at 3:14 AM
    lodawg
    lodawg [OP] Member
    Lithonia , GA
    BLACK 2011 DBLE CAB
    I have a set of 16 off-road oem alloy rims ,will the sensors from them fit the 17 oem alloy rims w/o having to rotate them 180 degrees ? Becuz I know in some the sensors are 20 degrees and 40 degrees.:confused:
  2. Apr 21, 2012 at 5:23 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    Yes, the TPMS for Toyota alloy wheels are all 20 degree sensors unless stated otherwise. The steel wheels use the 40 degree sensors. As long as you aren't switching between alloy and steel you should be fine. You might want to get a gasket kit for the sensors though to make sure there are no leaks
  3. Apr 21, 2012 at 6:26 AM
    jeepinoutwest
    jeepinoutwest Well-Known Member
    So what your saying is that since I plan to upgrade my OEM steelies to alloy rims the TPS sensors wont swap over? How about if I just take then sensors, wrap them in bubble rap and place them inside the pressurized spare tire? I do realize they would be destroyed if I ever used the spare.
  4. Apr 21, 2012 at 6:44 AM
    joe54tacoma
    joe54tacoma Joe in Indiana
    Joe
    New Albany Indiana
    2012 DOUBLE CAB TRD Sport
    someone on this site put them in a piece of pressurized pvc pipe.
  5. Apr 21, 2012 at 6:53 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    There are several ways to go changing from steelies to alloys.
    1. Rotate sensors 180 degrees.
    2. Pipe Bomb
    3. Wheelbarrow tire/spare tire
    4. Rim bands
    5. Buy super expensive toyota rebuild kit.
    6. Buy tire shop no so expensive sensor rebuild kit.
    OEM alloy swaps one for one.
  6. Apr 24, 2012 at 12:28 AM
    CmonMan
    CmonMan Member
    Kunia, HI
    '12 DCab in the works
    Can you use TPMS sensors from another Trd sport truck? My brother has an 06 sport and needs new tires. I have a 12' sport and am getting new rims and tires and my tires are practically brand new. Can I just trade my set with him and swap his TPMS into my new rims and he just take my stocks?
