(!) Tire Pressure Monitoring System
Discussion in 'Wheels & Tires' started by Rich Beauregard, Oct 2, 2009.
  1. Oct 2, 2009 at 3:06 AM
    Rich Beauregard
    Rich Beauregard [OP] Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Okay, I've had a nail in my tire in the past and when the pressure went lower in that tire the (!) Light would light up to let me know I had a low tire. NOW, I had new wheels put on a week ago, and the TPMS were working fine in the new rims/tires until yesturday. I was on my way into Pittsburgh when the light (!) came on and started to "flash" on & off. I called my dealer and the service guy said that means one of the sensors is broken or the main sensor computer is bad. MY QUESTION: How can I tell which sensor it is? My spare tire has a sensor in it (Spare has been sitting in my garage, not under the truck) and if I know which tire has a bad sensor, I will use the sensor out of my spare to replace the bad one. Any help appreciated. Thank you in advance, Rich
  2. Oct 2, 2009 at 3:31 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I hate that shit! Glad it's only on the wife's RAV4! Unplug the module & go without it if possible.
  3. Oct 2, 2009 at 4:04 AM
    Rich Beauregard
    Rich
    New London, CT
    You should have heard the service guy, He sounded all excited like he was going to make some easy money. He said "When can we schedule your visit" I said I'd cut the wire to the light before paying money over a blinking light.
  4. Oct 2, 2009 at 4:15 AM
    TRDnAZ
    TRDnAZ Well-Known Member
    Chandler, Arizona
    Desert Sand Mica
    I believe the dealer service guys have a remote scanner that they use to walk around the truck with to scan each sensor to check its status i.e. weither it working or not.
  5. Oct 2, 2009 at 4:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    If you spare is in your garage and you left a certain radius (Some folks say 50 miles or so...I'm not sure about that) or spent a certain amount of time with the truck running while away form the spare the light might go off. I'd try throwing the spare in the bed or whatever and seeing if that fixes it??
  6. Oct 2, 2009 at 4:51 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I was thinking the same thing...I'm sure there was a similar post about this and all 5 sensors have to be on/near the truck for the system to work properly. I'd say put the spare back on the truck and see if it works before doing anything else.
    If a sensor is broken, I'd see if the place that installed the tires would fix it before the stealership.
  7. Oct 2, 2009 at 5:37 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    The spare tire having the sensor and not being with the truck is causing this problem. Why is your spare in the garage and not under your truck?
  8. Oct 2, 2009 at 5:58 AM
    stephbm6
    stephbm6 Well-Known Member
    West Jordan, Utah
    2006 TRD Double Cab
    Who ever put your new wheels & tires broke one of your sensors. I've changed my wheels & tires 2 times and they broke one sensor both times. They put a new sensor on and then I had to take it to the dealer to calibrate it to my truck.
  9. Oct 2, 2009 at 7:11 AM
    cornwall325
    cornwall325 Toyota newbie...
    Jonathan
    Virginia
    09' D.C. TRD Sport 4x4
    Seatbelt chime turned off, Toyota bedmat, Wet Okoles, stock other than that.
    Agreed. I'd say you went too far away from the spare and the TPMS system isn't happy now.
