tire pressure on Nitto Ridge Grapplers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Marc2017toyguy, Feb 5, 2019.
  1. Feb 6, 2019 at 12:22 PM
    #41
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    shitty how.... they pretty much own the street tire game, best tire I've ever owned was the pilot super sport on my evo, know dozens of people that swear by Michelin tires. Maybe they just weren't right for your application but calling Michelins shit tires is a big lol.
    Sergio W, brehew and TacomaSport86 like this.
  2. Feb 6, 2019 at 12:29 PM
    #42
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    He's talking out of his other end...
  3. Feb 6, 2019 at 12:47 PM
    #43
    Nettleberger
    Nettleberger Well-Known Member
    2017 Tacoma TRD Pro DCSB Super White
    So calculating would get you roughly 36.72 psi? Not that anyone measures pressure to that the decimal - this is more for my understanding of the math that I was learning it correctly. (Each psi step is a delta of 37 on the load so at 35 psi load is 1890 + 1.7*37 hence 35+1.7 = 36.7)
  4. Feb 6, 2019 at 1:07 PM
    #44
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I use to love Michelin tires but after about 5 sets on suburbans they ride great but dry rotted very easy, they own bf Goodrich and again love the tire. But those too are a high ass maintenance tire. If your running the pilots on a road course maybe so but for my fun cars nitto drag radials hook better than the pilots all day long. For my wife's Lexus once the stock Michelins were worn out I got better riding and longer lasting tire out of a set of Fusions. To me they are now over rated and way over priced, just like the k02s. Give me a Toyo or a Nitto all day long.
  5. Feb 6, 2019 at 1:18 PM
    #45
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    That was the point I was ultimately trying to make. Running the same PSI that works in a 4ply may not be best for a beefier tire (ie 6, 8, 10ply, etc). Like you said above wear will most likely be compromised among other things due to heat alone. I was just trying to say it wont be likely that the stock tire PSI works perfectly for the Nittos.
    Sungod[QUOTED] likes this.
  6. Feb 6, 2019 at 1:21 PM
    #46
    Nettleberger
    Is your truck heavier in the front? Standard 3G Tacos are heavier in the rear so I would have expected those numbers to be flipped.
    ChadsPride[QUOTED] likes this.
  7. Feb 6, 2019 at 1:24 PM
    #47
    trazerr
    Oregon
    Hmm I would assume the opposite. That engine weighs a decent amount. The bed is pretty light (when empty). That’s my thought at the least. Been wrong once or 15 times though.
  8. Feb 6, 2019 at 1:24 PM
    #48
    ChadsPride
    Sponsored by TacomaWorld.com
    :notsure:
    Just seems like the sweet spot. I used to run 36 on all four.
  9. Feb 6, 2019 at 1:33 PM
    #49
    Nettleberger
    That was my exact thought... but... 2910lbs front / 3280lbs rear
    trazerr[QUOTED] and ChadsPride like this.
  10. Feb 6, 2019 at 1:34 PM
    #50
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
  11. Feb 6, 2019 at 1:36 PM
    #51
    Nettleberger
    and older gens - like gen 2s (2013) were actually factory spec'ed with higher psi in the rear:
  12. Feb 6, 2019 at 1:38 PM
    #52
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    This is literally worse than an oil thread..
    :popcorn:
    Joe671, Sungod, kakwvu and 3 others like this.
  13. Feb 6, 2019 at 1:45 PM
    #53
    trazerr
    Oregon
    GAWR is the gross axle weight rating (not the actual weight of the truck). Its the max each axle can handle. The rear is a straight axle and can handle more weight than the IFS.
    ChadsPride and Paul631 like this.
  14. Feb 6, 2019 at 1:47 PM
    #54
    Nettleberger
    yep agreed - just noting that the numbers are nearly the same as a the previously spec gen 2 with offset tire pressure with more in the rear so as to support heavier loads... weird that at nearly the same weight and tire size the gen 3 doesnt have the same spec for tire pressures front and rear
  15. Feb 6, 2019 at 4:47 PM
    #55
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I tried 2 sets of MS2s on my '07. Both succumbed to dry rot at 30,000.
    I said they are, "the shittiest tire I ever owned"... I stand by it.
  16. Feb 6, 2019 at 4:50 PM
    #56
    VaToy
    Parts Unknown
    I second that, shit tires they are, never lastedl. several sets on 3 suburbans and 2 Lexus, and they dry rotted.
  17. Feb 18, 2019 at 7:32 AM
    #57
    Sungod
    Sungod Well-Known Member
    St Augustine
    It is funny that you say they dry rotted. All tires dry rot, but Michelins tend to get that knock because they last so long that you see what happens to tires when they get old. Most other tires are well worn out before that starts to happen.
  18. Feb 18, 2019 at 7:38 AM
    #58
    VaToy
    Parts Unknown
    They dry rotted out in two years, they were replaced and they did it again. My vehicles stay in a climate controlled garage and never had an issue out of my Nittos on my Mustang and they are 10 years old with 8k miles on them.
  19. Feb 18, 2019 at 7:55 AM
    #59
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    How often to you guys change out the old air in your tires? I'm running 30psi in my Nittos, if that makes a difference.
  20. Feb 18, 2019 at 7:55 AM
    #60
    coopcooper
    alberta canada
    two times a year, I changed out my summer air for winter air last week
