tire pressure on Nitto Ridge Grapplers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Marc2017toyguy, Feb 5, 2019.
  1. Feb 18, 2019 at 7:57 AM
    #61
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I run nitrogen so the air pressure doesn't fluctuate much at all. Tires are set to 30 cold and very seldom do I see it any lower than 29 and after driving it goes up to 31 lbs.
  2. Feb 18, 2019 at 8:00 AM
    #62
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Just twice. Good to know.
    I was letting some air out the other day to hit the trails, and I could tell by the smell mine was getting stale.
    Makes me wonder if the shop put some old air in when I had the tires changed out.
    Can't be good for inner tire longevity..
  3. Feb 18, 2019 at 8:01 AM
    #63
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I hear if you don't change out your air at least twice a year you get dry rot, just a friendly heads up.
    jmneill[QUOTED] likes this.
  4. Feb 18, 2019 at 8:01 AM
    #64
    VaToy
    Parts Unknown
    Maybe they had some water in the air lines then it smells later when you air down.
  5. Feb 18, 2019 at 8:03 AM
    #65
    jmneill
    SE
    Thanks. I think I'll just go with three times a year to be on the safe side. I have my own compressor, and good clean mountain air.
    I'll also do it on a day with low humidity.
    coopcooper[QUOTED] likes this.
  6. Feb 18, 2019 at 9:01 AM
    #66
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    Not sure if this helps but.....
    I have the same size tire on a 16 inch wheel. I put them all at around 37.5 to 38 psi....the gauge in the truck should say 36 cold as it reads a little lower. My truck handles the best on the highway with this pressure.
    Our 4runner has the exact same size tire as yours and run the same pressures 37.5 to 38 for the highway.
    Anything less than this and handling is sloppy (I come from driving a 350z for 10 years )
    Tacoma is running destination AT's and 4 runner is running Bridgestone Revo 3's
  7. Feb 18, 2019 at 12:51 PM
    #67
    Sungod
    Sungod Well-Known Member
    St Augustine
    That Tennessee air has a bit of a twang to it. You should probably order Chilean air off Amazon.
  8. Feb 18, 2019 at 12:55 PM
    #68
    jmneill
    SE
    Good call.
    I've got Prime, and the last thing I need is to get some banjo music caught in a tire.
