Tire pressure (psi) for best tire durability and MPG.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by j102, Nov 16, 2015.
  1. Nov 16, 2015 at 3:56 PM
    j102
    j102 [OP] Well-Known Member
    2016 Tacoma SR5 4x2 Double Cab Short Bed.
    Hi All,
    I have the stock Hankook tires (P245/75R16) on my 2016 Tacoma.
    What pressure should I run on them for best tire durability and mpg?
    The driver's door says 32psi, and I have 33psi on them now.
    Thanks!
  2. Nov 16, 2015 at 4:04 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I'm running 35psi in my Hankook's.
  3. Nov 16, 2015 at 4:36 PM
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    The pressure on the door is the recommended rating for any tire on the vehicle as it is derived from the vehicle weight. Has nothing to do with the tires themselves. NOTE: this is for the recommended tire size for the vehicle. If over-inflated you will wear out the center, under-inflation and you wear out the outer edges.
    DustStorm4x4 likes this.
  4. Nov 16, 2015 at 4:48 PM
    mobgma
    mobgma Well-Known Member
    Edmonton, AB, Canada
    2016 Toyota Tacoma TRD Double Cab Long Box
    Sorry, to recap...
    Do we run the manufacturer of the tires recommended air pressure for the load or run the Toyota truck side door pressure?
    Are the pressures effected if you go up a tire size?
  5. Nov 16, 2015 at 4:53 PM
    Sam B
    Samuel
    Poway, Ca.
    none
    Run the door pressure. Typically the pressure is not affected when going up in tire size. 32psi is 32psi! are the load properties the same on both? Rating? I dont recall the load rating on the stock tires.
  6. Nov 16, 2015 at 5:02 PM
    mobgma
    For example. I have cooper ST Maxx. They say to run 50 PSI, if I don't they won't acknowledge warranty on the tire (on top of having to rotate). Toyota side panel says to run lower pressures. What to do...
  7. Nov 16, 2015 at 5:06 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Who says to run 50 PSI?
    The PSI on the side of the tire is the max pressure, run the pressure listed in the door.
    Kevindust likes this.
  8. Nov 16, 2015 at 5:11 PM
    bdunna
    bdunna Well-Known Member
    2005 tundra access cab
    Mine tend to get dry rot long before I burn half the tread.
    I tend to run around the recommended door pressure unless towing and tires looking sad.
  9. Nov 16, 2015 at 5:19 PM
    bdunna
    Won't have my truck for at least a month (if I'm lucky), but this is my number one pick for tires. Would love to see a picture. Planning on stopping on the way home so the wife doesn't see my stock tires. She doesn't get it.
    My two son's understand....
    be_unscared likes this.
  10. Nov 16, 2015 at 5:33 PM
    Sam B
    Samuel
    Poway, Ca.
    none
    What is the rating of the tire? Instead of listening to Bubba Gump at the tire shop, call or email Cooper Tires. I deal with this crap all the time...my daughter goes and gets tires rotated and then comes to my house to check them. They are the rated tire for the vehicle and the door shows 32. I check and the tire place puts in the max on the sidewall (45). So if you vehicle weighed another 2000lbs then 50psi might be correct. I had coopers on my Jeep and ran them at the door listing unless I aired down for wheelin. If Cooper says run 50 no matter what then I would run 50.
  11. Nov 16, 2015 at 5:36 PM
    Sam B
    Samuel
    Poway, Ca.
    none
    Also running over-inflated tires causes other issues... Handling, noise. I felt something odd the day after I picked up my truck and the tires were over-inflated for the transport. Aired down to 32 and no more issues.
  12. Nov 16, 2015 at 5:52 PM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    For better tire durability and MPG as your focus, run closer to max cold inflation listed on the tire. You can improve your MPG by big %. There will be compromises such as a rougher ride, possibly less grip on wet roads which you should test out, however you may see better resistance to hydroplaning with higher psi.
    I feel a lot of tire wear occurs when turning, which is where extra pressure helps them last.
    I find on my vehicles I get LESS tire wear when I have pressure considerably higher than door sticker and you can notice the vehicle rolls easier. It can even be safer because tires run cooler especially loaded.
    If you run snow tires, I'd only run them at 32psi max since snows seem to wear more in the center and tires are expensive.
    jerseymike and CusterFan like this.
  13. Nov 16, 2015 at 6:44 PM
    mobgma
    Max pressure for the cooper st maxx's is 80 PSI. Shop said run 50psi as that is what cooper recommends. Toyota door says 32 psi or whatever (but does that assume stock tire and tire size). I will try the door pressure.
  14. Nov 16, 2015 at 6:48 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I don't think you'll like 32 psi with those.
  15. Nov 16, 2015 at 6:49 PM
    mobgma
    Talk about confusion ahaha!
  16. Nov 16, 2015 at 6:53 PM
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    I run 34 35
    a400ryan and CusterFan like this.
  17. Nov 16, 2015 at 6:56 PM
    ARCHIVE
    Eric
    80 psi means you have load range E, enough for 1 tons. I think you'll be happy in the 38-50psi range.
  18. Nov 16, 2015 at 7:05 PM
    Markc1024
    Markc1024 Well-Known Member
    Proper tire pressure will vary by the tire size and characteristics. Toyota recommended pressures vary by 3psi depending upon which tires your vehicle came with. If you alter size beyond the OEM options, proper pressure could vary even more. As noted, you need to see how a given pressure/tire combination works on your vehicle and that just requires some testing.
    ARCHIVE and CusterFan like this.
  19. Dec 8, 2015 at 9:22 AM
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    since the weather cooled my tire pressure at start up is 26 once i roll down the road a couple of miles it goes back up to 30! thats on a trd off road dc sb stock tiers. do i need to add more air to them for (winter) although one day is 40 degrees the next is 80 here in Louisiana!
  20. Dec 8, 2015 at 9:42 AM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    I increased the pressure on my stock Goodyear's to 34 PSI all around. It helped MPG and it also feels better going down the road. 29 PSI was just too spongy for me.
    CusterFan likes this.
