Tire pressure (psi) for best tire durability and MPG.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by j102, Nov 16, 2015.
  1. Dec 8, 2015 at 10:42 AM
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    They should be what is stated in the manual for your tire type when cold. Once they heat up they would be in the 34-35psi range. It's really important to run the correct pressure in the winter according to the vehicles GVWR (and that pressure is in the door sill) to prevent hydroplaning and get the best tire to road contact.
    sxe4533[QUOTED] likes this.
  2. Dec 8, 2015 at 12:39 PM
    CanyonRunner
    CanyonRunner 100% PENETRATION
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
    I run my BFG KO2's E rated 265/75/16 at 35psi
    CusterFan likes this.
  3. Dec 8, 2015 at 12:47 PM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    I agree. Let me add that anything around the tire pressure recommendation will not make much diffence but you should add some with loads. Anything up to 35 lbs is fine if it's cold weather in the winter ss sudden temp drops can take a few pounds out. So in the summer for general driving, I keep the 32lbs, for loads and/ or cold weather, 35 lbs. This is for OEM size tires.
    These are always COLD pressures so in hot weather, expect them to be higher later in the day. Don't take air out if a hot tire is 36 lbs and when it's cold, it is 32 lbs. it's the cold temp that you measure the tire by.
  4. Dec 8, 2015 at 8:11 PM
    broders
    broders Well-Known Member
    NC
    2016 Toyota Tacoma TRD Sport DCLB
    When I bought my truck in October they were filled to 28 PSI. I haven't touched them since. Wouldn't they come from dealer with correct PSI?
  5. Dec 9, 2015 at 4:10 AM
    j102
    j102 [OP] Well-Known Member
    2016 Tacoma SR5 4x2 Double Cab Short Bed.
    Sometimes the dealer doesn't pay enough attention. What's the number on the driver's door?
  6. Dec 9, 2015 at 4:11 AM
    j102
  7. Dec 9, 2015 at 4:23 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    In short, no.
    Im one who always follows the door sticker recommendations, and usually run stock size. Mine are constantly over inflated by 5-7 psi if it goes into the dealer for something.
  8. Dec 9, 2015 at 4:57 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    The sticker on the door jamb is all about the tires that came on the truck....This info can be totally useless if you change brands or sizes.....and especially worthless if you switch to a different style of tire.
    If I ran the "door jamb" pressures in my 265/75/r16 Duratracs, they'd shake my eyeballs out.....Even at 35 psi, they had a BAD vibration in all 4. Balancing didn't fix that. They were balanced PERFECT. What it took was 38 to 40 psi. THEN they rode smoother'n I'd ever imagined a more aggressive tread pattern was capable of. Low PSI (Below 35) and the gas mileage dropped by more than 5mpg from stock rubber. With 38, I'm getting north of 20 most of the time. Chalk test (@ 38psi) showed less than 1/4" at the very edges of the tread NOT making full contact . Tires are wearing great, ride VERY smooth, the truck handles well, and I'm getting good mileage......with psi well ABOVE what's "on the door".
    Just for the record, I ran 'em @ 30psi for ONE DAY.....I probably still owe someone for gas I used that day. Mileage SUCKED. Truck rode like I was driving on a water bed. And the tires were their noisiest. Not to mention all the vibration.....
  9. Dec 9, 2015 at 5:24 AM
    broders
    NC
    When I turned on my truck this morning the PSI read 25, after about 20 mins of driving it climbed to 28. Should I fill my tires to 29 first thing in the AM before driving it?image.jpg
  10. Dec 9, 2015 at 5:38 AM
    Mmelaney
    Mmelaney Well-Known Member
    Waynesboro, GA
    2016 TRD Sport DCLB
    At a minimum, yes. I inflated to 35 cold and increased my mpg by about 1/2 mpg. I like the ride better but it's a personal choice.
  11. Dec 9, 2015 at 5:43 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    This is true!
  12. Dec 9, 2015 at 7:09 AM
    3dBdown
    3dBdown Well-Known Member
    2016 DCLB BBP 4x4 Sport
    Here is a good bit of info on temp/pressure. 2-4 psi over will help from being underinflated due to bleed-off which is way worse and more dangerous than being a few psi over which has no negatives. Somebody did a study (can't remember who) and showed that most people don't check often enough and wind up chronically under due to bleed-off.
    Tires sidewall is not a recommended pressure, nor is it the max that the tire will safely hold. It is the pressure required to carry max load of the tire.
    The range of slop is several PSI as far as tire wear and general performance, but being significantly over (for a given use case) will cause wear issues, rougher ride, and significantly under can cause wear, heat, and potential danger of failure problems.
  13. Dec 9, 2015 at 7:28 AM
    REDTRD
    REDTRD Woods & Water Edition
    Anthony
    Western NC
    07 DCSB SR5 4x4
    Click my build thread!
    Just checked my receipt from discount tire when I had new BFG KO2's installed a couple weeks ago. 35 in the front 40 in the rear. Maybe lower the pressure in the rear abit?
  14. Dec 9, 2015 at 8:09 AM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    That's pretty low pressure for E1 tires, but that's just me.
  15. Dec 9, 2015 at 8:23 AM
    #35
    be_unscared
    be_unscared Wardaddy
    Brendan
    So Cal
    2016 TRD Sport 4X4
    Im running the stock tires still on my sport. Door says 29psi, I have 30 cold… wondering if I should bump it up a few!
  16. Dec 9, 2015 at 8:41 AM
    #36
    dontstealmyride
    dontstealmyride Well-Known Member
    SLC, UT
    2016 TRD sport MGM sortbed
    I was at the toyota dealer last night and the service manager said here in Salt Lake City during the winter months they recommend having them filled to 38psi and that is what they set them at during service between Nov-March months and 34psi Summer months.
  17. Dec 9, 2015 at 8:43 AM
    #37
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    That's so they cut through the snow better. Not very good for the tire but won't kill it.
  18. Dec 9, 2015 at 8:47 AM
    #38
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Rear tires should have less pressure than fronts when the engine is in the front
  19. Dec 9, 2015 at 12:21 PM
    #39
    Sam B
    Samuel
    Poway, Ca.
    none
    Only on some vehicles Eric!
