Tire pressure(psi) question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jw1983, Feb 10, 2012.
  1. Feb 10, 2012 at 1:36 PM
    jw1983
    jw1983 [OP] Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    When I had bought my Tacoma in September of last year I had noticed that the PSI in the tires was 29 psi. In the place that I live in the temps in the winter time can go up and down a lot within the day. The TPSM came on when it was at that PSI just when winter was coming. I filled up the tires to 36 PSI. I have had them at this level since November and haven't had any problems. When I had taken a highway trip, I was getting horrible kms when it came to highway travel. I was getting around the same kms on city. Once I upped to 36 PSI. I was getting over 100 kms on highway with that then at 29 psi.
    So my question is, is it okay to have them at 29 psi? Even though the manufactors say that's what they recommend? Is it okay with me just having it at 36 when I am comfortable and what not?
    Any information would be great. Thanks
  2. Feb 10, 2012 at 2:20 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    maybe call dunlop or whichever company makes your tires, they can tell you what psi you should run them at:)
  3. Feb 10, 2012 at 2:42 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    running them way high can cause a blowout at speed. theyll get hot... id chalk the tires faces and see how they wear the chalk off. adjust air accordingly
    spitdog likes this.
  4. Feb 10, 2012 at 4:23 PM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    I keep mine around 34 psi year round.Tires wear good but ride is a little rougher.The book says if you run high speed a lot to inflate 3 psi more than the door jamb says so you could at least run 32 all the time for better MPGs.
  5. Feb 10, 2012 at 4:27 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    CVT Mt. Bachelor on a home-built bed rack.
    32 is always my starting point.
  6. Feb 10, 2012 at 4:30 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I do 34 on my Goodyear Wrangler P265/70R17. But google "Chalk Line Test" and set accordingly.
  7. Feb 10, 2012 at 5:24 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    35 -36 PSI got me 60K miles from the cheapo Dunlops. They are rated to be filled over 40 PSI but I can't exactly remember how much over.
    That was highway and city driving.
    Toyota suggests less PSI in order to give you a smoother less bumpy ride.
  8. Feb 10, 2012 at 10:26 PM
    badger
    badger Well-Known Member
    07 SR5
    The amount of pressure required in the tires depends somewhat on the tire itself, but mostly on the weight of the vehicle. That is why the recommended pressures are given by the vehicle manufactures, not the tire manufactures. The maximum pressure listed on the tire is to be used when the maximum load listed is on the tire. The chalk test is a good place start if you think the pressure listed by Toyota is off.
  9. Feb 13, 2012 at 5:25 AM
    kb1jop
    kb1jop Well-Known Member
    Rick
    Springfield, MA
    2010 Barcelona Red 4WD DCSB 6-Speed SR5
    Factory Towing Package Factory Roof Rack OEM Bed Mat Trifecta Tri-Fold Tonneau SeatSaver Custom-Fit Seatcovers WeatherTech Custom-Fit Floor Mats Block Heater: http://www.metrotpn.com/ProductDetails.aspx?CollectionID=13&ProductID=191&SortIndex=9
    Max. PSI on the stock Dunlops is 51. I run 38-40 all year round. Have 25k and they are like new.
  10. Oct 21, 2015 at 12:47 PM
    Dr_Kevorkian
    Dr_Kevorkian Well-Known Member
    California
    2nd Gen Pyrite Mica AC
    Dont want to start a new thread so Ill attempt asking it here.
    What would you guys run 265/75/16 BFG Mud-Terrain KM2's at? Load Range E....
  11. Oct 21, 2015 at 12:48 PM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    32 rear, 29 front
  12. Oct 21, 2015 at 12:50 PM
    Dr_Kevorkian
    California
    That low?
  13. Oct 21, 2015 at 12:52 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    yes, you can go higher if you want to but that will do just fine
  14. Oct 21, 2015 at 12:59 PM
    Dr_Kevorkian
    California
    Im guessing this is the best PSI for the best tire wear?
  15. Oct 21, 2015 at 1:02 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    exactly, but even if you do go higher they will wear about the same but the ride won't be as great. just don't go too high
  16. Oct 21, 2015 at 2:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Running with low tire pressure causes heat and blow outs ( side wall failure ).
  17. Apr 27, 2016 at 4:18 AM
    Jerm2006
    Jerm2006 Member
    Jeremy
    Columbia SC
    13' PreRunner TRD Sport
    I still have the stock dulops, 45K but had the vehicle for 15K. I noticed my ride was rough when I bought the vehichle and lowered the pressure to what the door say, around 30-31. I got extreme side tire wear and had tire rotated and aligned and 5K later same where on the new front tire...talking really bad. Finally I checked the side wall of tire since I was before thinking maybe alignment issue and the side was says up to 51 psi max. I recently increased to 40 psi after also talking to Toyota service rep. Hoping tires will last longer now. I am not sure why Toyota recommends a low pressure that will cause such extreme tire wear on the outsides of the tire as they are almost bald in 5K miles at the edges.
  18. Apr 27, 2016 at 7:40 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-235/85/16
    Load range E is a robust tire- probably can run these at about any PSI you want- as stated though the lower the PSI the more heat they generate also as mentioned 29 is probably a good start point. I generally air up on the higher end of the scale for better MPG and better on road handling. I also usually run my tires a little more in the front then than the rear. The front has more weight and corning loads to contend with then the rear. Lower PSI will allow the tire sidewall to flex some and give a smoother ride - Play with it, there is really nothing to hurt- dial in the pressure you like for the tires you have- what works for my brand will not necessary work for yours. Start with comfort because you can do that back to back testing really quick over a couple of days maybe, then check for mileage. If you want better mpg air the pigs up. At some point the tire may crown- this is what the chalk test is for, driving through a puddle or a changing from a dusty road to paved- just looking at the tread to see how much of a contact patch you have rolling in a straight line. You may find with higher pressures that you have only 3/4 of the tire in contact with road surface going straight- most people like to have all the tread in contact so air down a couple of pounds until you see the wear pattern across the tire. Again I usually find that my fronts I run a little higher than the rear. Somewhere in there is happy medium that YOU will like. Cheers!
    High voltage and spitdog like this.
  19. Apr 27, 2016 at 9:36 AM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    The pressure recomendation is a happy medium for all driving environments and situations. Think empty truck, towing or heavy loads, pavement, dirt etc. the tire companies have no complaints about selling more tires because of under inflated tires wearing faster on the outside edges. 90% of drivers never change or adjust inflation for optimum use. I have OEM stock BFGs still and carry a small air compressor on board. I have run tall rubber 36-40 psi for city driving and lower pressure when going off road 29-32 psi. Afterwards I Fill em' back up for city use. Been doing this for 20 years on all my vehicles and I have always had even tire wear.
    Every tire should be adjusted for its rating and environment for best results.
    Chalk test helps see where you're at also.
  20. Apr 27, 2016 at 10:32 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    +1, PSI on door jamb is only good for stock OEMs. I have BFG ATs load range Ds from factory and Toyota sent me a sticker for 46 lbs. I have kept 46 in them until last month. I now have 42. They will go 70k+ easily. I am at 66.5k and no where near the wear bars. The ranch I run is hard on tires. I had 265/75/16 Duratrac load Cs on my '09 Prerunner and Discount said to run 42 in them. 42 seemed about right based on tread wear when I sold it.
